New Reply
Binomial distribution and lottery
Share Thread Thread Tools
Feb20-12, 04:49 AM   #1
Hi there, I'm looking at a problem and wanted some help to advise if I'm going in the right direction.
I need to test if the number of times a lotto ball has appeared in a draw fits a binomial distribution. I have collated the data and ultimately will do a hypothesis test.
The draw consists of 5 balls from 1-50. there have been 347 draws to date and therefore 1735 balls drawn. Taking ball number 1 which has been drawn 31 times as an example I need to check that if the number of times it has been drawn fits a binomial distribution.
I know the formula for the bin. dist but wondered what values for the probability and what number I would need to use. Once I know this would I then set up a hypothesis test at 5% siginificance level to see if the null hypothesis is rejected or accepted?
Thanks for your help in advance.
felix
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Feb20-12, 06:17 PM   #2
Quote by FelixHelix View Post
felix
What you'd want to do is perform a two-tailed z-test (since np and n(1-p) are > 5) with mean = 347/50 and sd = sqrt(347/50 * 49/50).
Feb21-12, 11:41 AM   #3
When you say two tailed would my X's (r.v) be the lowest value of a number appearing (in this case 25) and the highest (and 51). Add a continuity correction 24.5 and 51.5 respectively and calculate the z test and see if it is significant?
New Reply
Thread Tools
Similar Threads for: Binomial distribution and lottery
Thread Forum Replies
Casio fx-9860G - calculating binomial coefficients and binomial distribution General Math 3
Relationship binomial distribution and central limit theorem + poission distribution Set Theory, Logic, Probability, Statistics 1
Binomial probability, similar to lottery problems. Precalculus Mathematics Homework 1
How is the negative binomial the inverse of the binomial distribution? Set Theory, Logic, Probability, Statistics 1
Derivation of the probability distribution function of a binomial distribution General Math 2
