Right angle triangle trigonometry
The discussion revolves around a right triangle problem involving trigonometry, specifically the calculation of an angle theta using the sine function. The original poster presents a triangle with a hypotenuse of 3 cm and an opposite side of 2 cm, seeking assistance in recalling how to determine theta.
  • Participants discuss the use of the sine function to find the angle theta, with some questioning the general application of the inverse sine function (sin^-1) for solving angles. Others reference the mnemonic SOH CAH TOA to clarify the relationships in right triangles.
Some participants have provided guidance on the application of the sine function and its inverse, while others are exploring the conditions under which these functions are used. Multiple interpretations of the problem and its solution methods are being discussed, indicating a productive exchange of ideas.
There is a lack of clarity regarding the original poster's understanding of trigonometric functions and their applications, as well as the specific requirements for solving the problem. The discussion also touches on the generality of mathematical functions beyond geometric interpretations.
aisha
The question says determine theta
I have a triangle with a hypotenuse of 3 cm
opposite the angle theta is 2cm length
and adjacent to that is unknown.
I don't know how to solve this question I don't remember what theta is lol or how to punch it in the calculator what do I do please help me refresh my mind. :confused:
You know that [tex]sin(\theta)=\frac{opp}{hyp}[/tex]
therefore
[tex]sin(\theta)=\frac{2}{3}[/tex]
[tex]sin^{-1}(\frac{2}{3})=\theta[/tex]
[tex]\theta=41.8 degrees[/tex]
ok so whenever I am solving for theta I use [tex]sin^-1[/tex] or do I use it whenever i am solving for any angle? what does [tex]sin^-1[/tex] do?
also how did u know to use [tex]sin[/tex] ?
SOH CAH TOA. Depends on what #s you have
1.Yes,the equation:
[tex]\sin \theta=a[/tex] is solved by applying on both sides of the equation the inverse function of "sin theta" (called [itex]\arcsin \theta[/itex]) which would giveu the result.Note the degree of generality:no (right) tringles involved,justmathematical functions.
2.For any angle,for any argument of the function "sin",nit necessarily an angle.E.g.solve this equation for "x"
[tex]\sin(x^{2}-4x+3)=-0.12[/tex]
"x"doesn't have the geomtrical interpretation of an angle,it's just "x",an arbitrary varible of a function f(x).
3.Solve for the angle? :rolleyes:
4.In a right triangle,the sine of an angle is defined as the ratio between the opposide side and the hypothenuse.Since u were given both the opposite side ("opposite the angle theta is 2cm length") and the hypothenuse ("hypotenuse of 3 cm"),it was natural to use "sin".
Daniel.
