Checking Axioms for a*b on the Set Z
  • Thread starter Thread starter mikael27
    Axioms Set
The discussion revolves around checking the axioms for group theory applied to various operations defined on specific sets. The original poster presents three operations: subtraction on integers, a modified addition on real numbers excluding 1, and multiplication on a set of powers of 2. Participants explore the implications of these operations in the context of group axioms G0, G1, G2, and G3.
  • Participants discuss how to verify the group axioms for the defined operations, questioning the closure property and associativity. They raise concerns about proving these properties symbolically without specific numerical examples.
There is an ongoing exploration of the axioms, with some participants attempting to verify G0 for the operation of subtraction on integers and others considering the implications of the modified addition on real numbers. Questions remain about the validity of the operations and whether they satisfy the group properties.
Participants note the importance of closure in the context of the defined operations and question whether certain values lead to contradictions in the axioms. There is also a recognition of the challenge in proving properties without concrete examples.
mikael27
For each of the following definitions for a * b and a given set, determine which of the axioms
G0, G1, G2, G3 are satisfied by a * b. In which cases do we obtain a group?
1) a - b on the set Z
2)a + b - ab on the set R | {1}
3)ab on {2^n | n in Z}
The four axioms for group are:
G0 For all a, b in G, a*b in G.
G1. Associativity. For all a, b, c in G, (a * b) * c = a * (b * c).
G2. Identity. a * e = a = e * a.
G3. Inverses. a * b = e = b * a.
How am i going to check these axioms for example 1 which says a - b on the set Z ?
If you subtract two integers, do you get another integer?
Does it matter the order you subtract integers?
Example is (2-3)-5 = 2-(3-5)?
Is there integer such any number minus that integer is the the original integer?
Is there an integer when subtracted to another integer you obtain the value(from above)?
Can you provide a counter example to any of the above? If so, you don't have a group. If not, prove them all which is somewhat trivial.
Ok but how are you going to prove these axioms with just these equations and letters without giving any number. I don't understand what is happening with the letters
Associative: is (a- b)- c= a- (b- c)?
Identity: does there exist an integer so that, x, such that a- x= x- a= a for all a?
Inverse: if there does exist such an a, given x, does there exist a y such that x- y= a?
if that is so, you have an uphill battle in learning group theory. i will try to explain, but maybe i won't do that so well.
a) to prove G0, where "*" is subtraction (that is, by a*b, we mean a-b), we need to show that for any two integers a and b, that a-b is in Z.
now, you might think, "which two integers"? it shouldn't matter. we use the letters a and b, because we aren't thinking of any two PARTICULAR numbers (like 3 and 5), but any two numbers at all.
since, there are an infinite number of integers, we just don't have the time or the space to verify a rule for "every" integer, unless we can do it SYMBOLICALLY. while certain rules for integers can indeed be proved "from scratch" (using only logic, and a suitable definition of "integer"), I'm sure your instructor will allow the following rules about integers to be taken "as fact":
a+b is always an integer
(a+b)+c = a+(b+c)
a+b = b+a
a+0 = 0+a = a
a+(-a) = (-a)+a = 0
ab is always an integer
a(bc) = (ab)c
ab = ba
(a)(1) = (1)(a) = a
a(b+c) = ab+ac
these are all rules that you should have learned many years ago. note that these rules are only true for the integers, for other sets, they may, or may not be true.
for your first example, you need to verify G0,G1, G2 and G3 for a*b = a-b. if at any point, one of the rules fails, you can stop there. i'll leave the verification of G0 to you. it may be helpful to remember that:
a-b = a+(-b)
for G1, we have to either show:
1) a-(b-c) = (a-b)-c, for EVERY set of 3 integers {a,b,c} -OR-
2) for AT LEAST ONE set of 3 integers, a-(b-c) ≠ (a-b)-c.
suppose a and b were zero, can you think of a c which shows G1 cannot be true for all a,b,c?
So for 1)
we have:
G0: For all a,b in Z , a-b in Z because a+(-b)
G1: For all a,b,c in Z (a-b)-c=a-(b-c) which is not true (how are we going to show this?)
Therefore it is not a group.
mikael27 said:
So for 1)
we have:
By reading post 2.
ok thanks.
Now for 2) which says a + b - ab on the set R | {1}
we have:
G0: For all a,b in R| {1} , a+b-ab in RZ because a+b+(-ab)
G1: For all a,b,c in R| {1} (a+b-ab)-c= a+b-(ab-c) ?
(a*b)*c is not what you've written out. It's
a*b+c-(a*b)c = a+b-ab+c-(a+b-ab)c
mikael27 said:
ok thanks.
we have:
G0: For all a,b in R-{1} , a+b-ab in R-{1} because a+b+(-ab)...?
this sentence is unfinished.
it should be clear that a+b-ab is indeed a real number. the question really is, is it in R - {1}?
if not, then we do not have closure. and the sticking point here, is we need to be sure that if a,b are real numbers that aren't 1, then a+b-ab is a real number that isn't 1.
ok, suppose a+b-ab = 1. then a(1-b) + b = 1, and a(1-b) = 1 - b.
is it ok to divide by 1-b? why, or why not? what do we get after we do?
ok.
G0: For all a,b in R| {1} , a+b-ab in R| {1}
So we need to check that a and b are real number excluding 1 as well as the expression a+b-ab.
Let a+b-ab = 1 , a(1-b) + b = 1 and a(1-b) = 1 - b
if b is not 1 then we divide both sides by (1-b) as 1-b is not zero.
which gives a=1 which is not acceptable.
Therefore G0 does not hold.
However even if G0 does not hold and it is not a group i have to check for G1,G2,G3.
What about G1?
mikael27 said:
ok.
What about G1?
i don't think you understand what you just did.
we first supposed that a ≠ 1, b ≠ 1.
you then showed that IF a+b-ab = 1, then a = 1.
that is, a = 1 is the ONLY value for a that makes a+b-ab = 1 true, so long as b is not 1, as well.
but a = 1 is NEVER true, since a is in R - {1}. so a+b - ab is never 1, so a+b - ab is in R - {1}. this PROVES G0, not disproves it.
for G1, you need to show that (a*b)*c = a*(b*c).
(a*b)*c = (a+b-ab)*c. to evaluate this, we need to treat a+b-ab as a single number:
a+b-ab = x (x is just temporary, we'll get rid of it later).
x*c = x+c-xc...now we can "substitute a+b-ab back in for x":
(a*b)*c = (a+b-ab)*c = x*c = x+c - xc = (a+b-ab) + c - (a+b-ab)c
= a + b + c - ab - ac - bc + abc
now you evaluate what a*(b*c) is.
x*c = x+c-xc. is this a rule ?
  • · Replies 16 ·
  • · Replies 24 ·
