| New Reply |
Electric car with the wind mill |
Share Thread | Thread Tools |
| Feb25-12, 01:50 PM | #1 |
I am mechanical engineer and working on a project of electric car havin a wind mill on the top.
i am using 7 lead acid batteries and a DC series wound motor. The car has a wind mill for the recharging of the batteries. I have read other thread on this forum which states that the wind mill on the car is not a productive idea. so whether it will be a good idea to use the wind mill only at the time when the car is parked. so that drag doesn't cause any work loss?? and how much size and the power wind mill i should be using??? Any relevant input will help |
| Feb27-12, 12:59 PM | #2 |
If you are a mechanical engineer as you claim to be, you should go through a simple thermodynamic analysis which shows your system and where the power inputs are. You'll find that the only way the windmill can "provide" power to the system is for it to sap it from the car's speed as wind drag, and this speed has to have been added to the car by the engine. This means your windmill is just adding drag to the system and not providing power.
You're wasting your time, save yourself the embarassment and stop while you're behind. |
| Feb27-12, 01:05 PM | #3 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: Electric car with the wind mill
| wind scaling and increasing wind speed for wind tunnel problem | Mechanical Engineering | 3 | ||
| Wind Power Vehicle Traveling Down Wind Faster Than The Wind | General Physics | 305 | ||
| Governing in case of Wind mill | General Physics | 2 | ||
| wind mill | Mechanical Engineering | 2 | ||
| Determine the Electric Power Produced by a Wind Turbine Over a Range of Wind Speeds | Advanced Physics Homework | 5 | ||
