Register to reply
Electrostatic problems help
by Genericcoder
Tags: electrostatic
Share this thread:
Genericcoder
#1
Feb26-12, 04:30 PM
P: 131
Hi guys I have 3 question the first one I want to check if my answer is correct or not but the two other question I don't know how to approach them thanks.
1)The 500 gram mass carries a charge of –7 x 10-8 C. If the coefficient of friction between the mass and the surface is 0.20, and an electric field of magnitude 3 x 107 N/C is horizontal and directed to the right, which is being treated as the positive x-direction. What is the acceleration of the mass?
Ff = force of friction;
Ff = 0.2 * (500 * 10^-3) = 10^-1N;
Fe = qE;
Fe = (-7 * 10^-8) * (3 * 10^7) = -2.1N;
Fnet = -2.1 - 10^-1 = -2.2N;
F = ma;
-2.2 / (500 * 10^-3) = a; --> a = -4.4 m/s^2;
I can't find that answer in the multiple question,so did I do something wrong here?
2)What is the magnitude and direction of the electric field generated by a 13 μC charge in a point 8.90 cm away from the charge?
How can I know the electric field generated even though I am not given a point charge ? Thats what confusing me in this question.
3)A +2 μC charge is at the origin. A +5 μC charge is on the x-axis at +1 m. At what point between the charges is the electric field zero?
I first calculated the electric field Electric field from
F = kQ1 * Q2 / d^2.
I got electric field of the 5μC = (9 * 10^4) / 5 and the electric field of the
2μC = (9 * 10^4) /2.
I don't know how to proceed from here to get the distance of the zero electric field.
This is not a homework or anything I am solving some electrostatic problems on my own.
Thanks for the help in advance.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
gneill
#2
Feb26-12, 06:08 PM
Mentor
P: 11,689
Quote Quote by Genericcoder View Post
You seem to have left out the gravitational constant. Frictional force is μ times the normal force. The normal force here is given by m*g.
Fe = qE;
Keep in mind that friction force always opposes the direction of motion. The friction force will oppose the force due to the electric field, thus decreasing the magnitude of the net force.
Unless told otherwise, assume that the charge is a point charge.
F = kQ1 * Q2 / d^2.
No, that's the force between two charges. You want to find the electric field due to each charge individually at some location and add them. E = k*Q/r2. Be sure to pay attention to the directions of the fields from each charge at a given location.
Genericcoder
#3
Feb26-12, 07:33 PM
P: 131
Thanks alot.
I still have problem for number 3 but I calculated the other problems as follows->
I have calculated problem 1 to be
fnet = -2.1 + 1 = -1.1;
f = ma;
a = -1.1/500 * 10^-3;
a = -2.2 m/s^2.
For problem two its really easy
E = (9 * 10^9)(13 * 10^-6) / (8.9^2) = 1.48 * 10^7.
I am still confused though for problem three I meant to say I first calculated the force then I went to see which distance will the force be zero but got nowhere from their.
I tried to resolve it by assuming that point charge for the electric field of the 2 is 5 and vice versa and got the equation.
E(due to 5) = (9 * 10^9)(5 * 10^-6) / (1 + x)^2.
E(due to 2) = (9 * 10^9)(2 * 10^-6) / (-1 + x)^2.
Then I added E(due to 5) + E(due to 2) = 0; but got complex solution I think here my logic is flawed. I know I must did something wrong in this procedure.
gneill
#4
Feb26-12, 08:04 PM
Mentor
P: 11,689
Thanks alot.
f = ma;
a = -2.2 m/s^2.
That's fine, but you have yet to state the direction which was asked for.
Your distance expressions look dubious. If x is the distance from the origin, then what does 1+x or -1+x represent geometrically?
In these problems where you're dealing with quantities that involve the same multipliers and constants you can usually discard the common factors when ratios or equivalences are called for. So let the charge at the origin be +2, the charge at x=1 be +5. Between the charges the field from the +2 charge will point to the right while the field from the +5 charge will point to the left. So clearly there will be a point between them where the "right pointing" and "left pointing" will exactly cancel.
If they cancel that means that their magnitudes will be the same.
[tex] \frac{2}{x^2} = \frac{5}{(1 - x)^2}[/tex]
Genericcoder
#5
Feb26-12, 08:24 PM
P: 131
Yes I made my distance expression wrong. I thought the electric field of 2 due to point charge 5 should be the distance of 1 where they are far apart plus x,which is the distance the charges cancell. I followed same logic in my other Electrical field,but yes that is wrong since I am adding a distance of 1 that is why my answer was flawed.
Thanks.
Register to reply
Related Discussions
Electrostatic force problems, help ! Introductory Physics Homework 2
Electrostatic Problems Introductory Physics Homework 2
Several Electrostatic Problems Introductory Physics Homework 3
Can someone double check to see if I did these problems correctly? E-Flux problems Introductory Physics Homework 3
Problems on Electrostatic Introductory Physics Homework 9
