The doubt of Seperation of Variables
The discussion revolves around the method of separation of variables in solving partial differential equations (PDEs). Participants explore the assumptions underlying this method, particularly whether solutions can always be expressed as a product of functions of the form X(x)T(t), and the implications of this for different types of PDEs.
  • Some participants question the assumption that solutions to PDEs can always be expressed as a product of two functions, X(x) and T(t).
  • It is noted that in practice, the method of separation of variables may not work for many real-world problems, as the equations often do not separate.
  • One participant suggests that while X(x)T(t) is a common form, solutions can also be represented as sums of such products, potentially capturing a broader range of solutions.
  • Another participant highlights that any initial condition function f(x) can correspond to a solution u(x,t) under certain conditions, and that Fourier's work allows for expressing any f(x) as a linear combination of the functions derived from separation of variables.
  • There is a mention that the discussed methods apply to linear systems, and non-linear PDEs may not exhibit the same properties.
Participants express differing views on the applicability of the separation of variables method, with some suggesting it is limited while others argue it can be generalized through sums of functions. The discussion remains unresolved regarding the extent to which solutions can be represented in the proposed forms.
Participants acknowledge that the discussion is primarily focused on linear PDEs and that the assumptions made about the nature of solutions may depend on specific conditions or regularities of the functions involved.
Chuck88
The method of separation of variables is used to solve the problem of partial diffrential equation. For example, when the partial differential equation is:
[tex] \frac{\partial u}{\partial t}-\alpha\frac{\partial^{2}u}{\partial x^{2}}=0[/tex]
We could suppose that [tex]u(x,t)[/tex] is a solution concerning both x and t. It could also be represented as the product of two functions:
[tex] u(x,t) = X(x)T(t)[/tex]
My question is that the method of separation of variables is based on the assumption that our solution could be represented as the product of two functions, which are with respect to x and t repsectively. My question is that what if the solution u could not be represented as the product of two functions of x and t, like:
[tex] u(x,t) = \frac{1}{xt+1}[/tex]
We then could not use the method of separation of variables.
I know that the solution I provided above is NOT RIGHT. But is it possible that the solution is of the form of the solution I provided above? Which means that the solution could not be separated that easy?
Okay two things, when you first apply the method of separation of variables to a PDE, there's basically nothing a priori to tell you that it will work. In fact in practice when you're doing a real problem as opposed to something from a textbook separation of variables is almost guaranteed not to work because the equation won't separate. But I think due to uniqueness results for the PDEs your working with, you can basically employ any trick you want to find a solution even if it involves an unjustified assumption, and if in the end it leads to a solution, you know that this is the unique solution.
The second thing is that you're not really strictly limited to functions of the type X(x)T(t). You're limited to SUMS of functions like that. And it turns out that this is in fact flexible enough to capture any solution.
I remember my friend and I had a discussion about this once. We were lead to some spectral theory stuff, and in the end I sort of forgot our conclusions...
Can I get the rough idea fron your reply that in fact, some solution to the partial differential equation could not be represented as X(x)T(t)? X(x)T(t) is one type of the solution?
It's highly unlikely you can find a solution to a PDE as [itex]\Psi(x,t) = X(x)T(t)[/itex], but it turns out you can find a solution to many (maybe even all? I'm not confident in saying all) PDEs as a series solution given by
[itex]\Psi(x,t) = X_1(x)T_1(t) + X_2(x)T_2(t) + X_3(x)T_3(t) + ...[/itex]
where each X(x) can be a unique function of x and similarly with T(t)
Lets say we're thinking about the above problem (heat equation) on some fixed domain with some fixed boundary conditions. So any function (maybe assuming some technical regularity conditions) f(x) can be used as the initial conditions for our problem and supposedly should correspond to some solution u(x,t), such that u satisfies the pde and u(x,0)=f(x). So do we know how to find the solution for any f?
Well if the f(x) just happens to be one of the Xλ we found while working through the separation of variables then obviously we're done. u(x,t) = Xλ (x)Tλ(t). Similarly if f(x) is some linear combination of such Xs then the situation is again pretty simple. Say
f(x) = α Xλ1(x) + β Xλ2(x)
then
u(x,t) =α Xλ1(x)Tλ1(t) + β Xλ2(x) Tλ2(t)
But the genius of Fourier (if i got the history wrong someone please correct me) was figuring out that you could actually express ANY f(x) as a linear combination of Xs, as long as you're willing to use infinitely many. So since there is a 1-to-1 mapping between solutions and fs (I'm sure you need to qualify this statement somehow with regularity conditions of f to make it actually true) and since for any f we can get a solution with separation of variables, it must be that we can express any solution u(x,t) using a linear combination of the X T products.
One should note that the above prescriptions work for linear systems. Non-linear PDE's will not have this nice property where you can add solutions to form new solutions.
Yes that's true. I was just speaking to the problem the OP mentioned, which is linear.
  • · Replies 18 ·
