How Can Contour Integration Yield Specific Values for Variable Conditions?
  • Thread starter Thread starter zoorna
    Integration
The discussion focuses on using contour integration to extract specific values from a Dirichlet series. The integral defined as I(x)=\frac{1}{2\pi i} \int_{\sigma-iT}^{\sigma+iT}\left(\frac{x}{n}\right)^{s}ds aims to yield a constant when x=n and zero otherwise. The user proposes modifying the function \frac{x}{n} or the contour itself to achieve this. Additionally, they explore using Perron's formula to derive the arithmetic function \alpha(n) from the integral.
  • Understanding of contour integration in complex analysis
  • Familiarity with Dirichlet series and their properties
  • Knowledge of Mellin transforms and their applications
  • Experience with Perron's formula in analytic number theory
  • Study the properties of contour integration in complex analysis
  • Learn about Dirichlet series and their convergence criteria
  • Research Mellin transforms and their role in extracting coefficients
  • Examine the application of Perron's formula in analytic number theory
Mathematicians, students in complex analysis, and anyone interested in analytic number theory and the extraction of arithmetic functions from series.
zoorna
greetings . this is my first post here . i am preparing myself for a complex analysis course that i will be taking next semester . i came across this problem , which is probably a very simple one , but i don't know how to go about it , so bare with me:biggrin:
we have the contour integration
[tex]I(x)=\frac{1}{2\pi i} \int_{\sigma-iT}^{\sigma+iT}\left(\frac{x}{n}\right)^{s}ds[/tex]
where [itex]\Re(s) ,\sigma > 1[/itex]
x is a variable , and n is a constant .
i need the integration to yield a constant if [itex]x=n[/itex], and zero otherwise ??
my guess is that the function [itex]\frac{x}{n}[/itex] should be somehow modified to yield the desired result - constant for x=n , zero other wise - . or is it the contour that should be changed ??
your help is appreciated .
i'll try to make the question a bit clearer . we have the dirichlet series :
[tex]I(s)= \sum_{n=1}^{\infty}\frac{\alpha(n)}{n^{s}} , \Re(s)>1[/tex]
where [itex]\alpha(n)[/itex] is some arithmetic function of n .
now i am trying to use mellin transform, or any kind of transform akin to that of fourier's, to extract [itex]\alpha(n)[/itex] . i was hoping for a kernel - function of s - that is orthogonal to all terms except for the one containing the integer i want to extract [itex]\alpha(n)[/itex] for . meaning , i am trying to find a function [itex]f(x,s)[/itex] such that :
[tex] < f(x,s),n^{-s}>=\left\{\begin{matrix}<br /> k & , & x=n & \\ <br /> 0 & , & o.w & <br /> \end{matrix}\right.[/tex]
k is a constant
i hope this makes it clearer .
i think i found it . using Perron's formula :
[tex]\alpha(n)=\frac{1}{2\pi i}\int_{2-i\infty}^{2+i\infty}I(s)\frac{\left(n+1/2\right)^{s}-\left(n-1/2 \right )^{s}}{s}ds[/tex]
