New Reply
How to sort a list alphabetically but ignore numbers?
Share Thread Thread Tools
Feb27-12, 01:00 PM   #1
I have a list of urls I need to sort but I need to sort them only using the letters in the url?
Eg.
example.com/174353/a
example.com/3452344/c
example.com/435322/d
example.com/2342/b
example.com/23456/e
Would be sorted as:
example.com/2342/b
example.com/23456/e
Thanks
AL
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb27-12, 02:41 PM   #2
if you process the file using the / as a separator then you can extract out the 3rd field to sort on.
you could probably use awk to do the parsing to write a new file containing the key then url on one line
then use the sort command to generate a sorted list.
thats if you're running on linux or some unix variant.
Feb27-12, 03:35 PM   #3
Most varieties of BASIC have a Right$(,) function, which would read the closing letter(s) off the target string.
Feb27-12, 03:38 PM   #4
Quote by jedishrfu View Post
I'm on Ubuntu 11.10.
The addresses aren't as simple as I thought here's one for example.
http:// www. flyforums. co.uk/fly-tying-step-step/160-beacon-beige.html
(The spaces are just there to stop it hyperlinking it.)
They all follow the same pattern with a number-couple of keywords separated by -s .html
Feb27-12, 04:00 PM   #5
how about this python script
http://snippets.dzone.com/posts/show/10115
Feb27-12, 04:08 PM   #6
It comes up with an error,
" File "sort.py", line 3, in <module>
filename = sys.argv[1]
IndexError: list index out of range"
Feb27-12, 04:51 PM   #7
Please clarify. Would the URL
be lexicographically sorted with the value
httpwwwflyformscoukflytryingstepstepbeaconbeigehtml
Feb27-12, 04:53 PM   #8
when you run it you're supposed to provide a file of your urls to be sorted.
./sorturls.py myfileofurls.lst
where sorturls.py is the name of the script and the myfileofurls.lst is your file of unsorted urls.
New Reply
Thread Tools
Similar Threads for: How to sort a list alphabetically but ignore numbers?
Thread Forum Replies
Using the Insertion Sort algorithm on a linked list Engineering, Comp Sci, & Technology Homework 1
Sort fullnames alphabetically Programming & Comp Sci 1
Ignore List Forum Feedback & Announcements 6
[SOLVED] ignore list Forum Feedback & Announcements 7
