How Does Relativity Affect Information Exchange Between Moving Observers?
The discussion centers on the effects of relativity on information exchange between two observers, A and B, with B moving at relativistic speeds. It highlights the Doppler effect, where B experiences redshift while moving away from A and blueshift when returning, impacting the rate of information received. The calculations reveal that B, over a two-year journey, perceives 10.1 years of events on Earth due to time dilation and the Doppler shift factor. The relativistic equations confirm that both observers experience time differently, emphasizing the non-absolute nature of motion in relativity.
  • Understanding of the Doppler effect in physics
  • Familiarity with relativistic time dilation equations
  • Knowledge of electromagnetic wave behavior
  • Basic grasp of reference frames in special relativity
  • Study the mathematical derivation of the relativistic Doppler effect
  • Explore the implications of time dilation in practical scenarios
  • Learn about the Lorentz transformation equations
  • Investigate real-world applications of relativity in modern physics
Students of physics, researchers in relativity, and anyone interested in understanding the complexities of time and information exchange at relativistic speeds.
SevenTowers
Hi,
This is a question to which I haven't found an answer anywhere, so I'm probably seeing this wrong but I can't seem to figure it out.
I realize time is warped relative to speed, what I don't understand is the following:
-Considering 2 people, A and B. Let us say that A is stationary and B is moving away from A at a speed very close to that of light (such as the famous twin paradox).
-Now consider that A is emitting an information bearing, electromagnetic signal towards B.
-The way I see it, while B is moving away from A, it is receiving a red shifted beam of information. B is "learning" a lot slower than if he were at rest.
-Now let B turn around at some point and move towards A at the same speed as he was moving away. B is now receiving a blue shifted signal and is "learning" at very fast pace.
-When B finally reaches A, he will have been subjected to all the information broadcasted by A, but at some point will have received it a lot faster, and at some point a lot slower.
- If B's time is running a lot slower as it is proven to, and A has broadcasted one year of his life, does this mean that B has seen everything that has happened in fast forward all the time? Even though the signal was red shifted for half of his trip?
I can't seem to put together the idea of an information exchange with time compression... I visualize electromagnetic waves as constant speed separated crests, which naturally seem closer together if you're traveling towards them, and further apart if you are traveling away.
In the same way, if B is sending EM waves while coming closer to A, A will receive a compressed signal followed from very close by the arrival of B (lets say B is traveling at 99.999999% of c)...
I know a drawing would help but if somebody understands what I'm trying to say could you please enlighten me? Thanx :)
You might find this particular subsection of the sci.physics.faq helpful
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_doppler.html
But i'll give a thumbnail sketch of what the traveller sees. The doppler shift factor, k is a function of velocity. So let's say that the doppler shift factor is 10:1.
On the outbound trip, B travels for some time period (let's say 1 year, to make it simple), at a doppler shift factor of 10, and sees the signals from .1 years of events on the planet.
On the inbound trip, B travels 1 year at a doppler shfit factor of 10, and since it turns out that the doppler shift factor is the recirpocal of what he saw on the outgoing trip - so he sees 10 years of signal in his 1 year return trip.
The net result is that B, on a 2 year trip, has seen 10.1 years elapse for the person who stayed behind.
When we look at the relativistic equations, this checks. The doppler shift factor is [tex]\sqrt{\frac{c+v}{c-v}[/tex]
ref:
http://scienceworld.wolfram.com/physics/DopplerEffect.html
So if your velocity is (99/101)*c, you will experience a doppler factor of 10 (substitute and check - also substitue v= -(99/101)*c into the formula above, and see that the doppler shift factor is indeed .1 on the outbound trip).
The formula for relativistic time dilation is
[tex]gamma = \frac{1}{\sqrt{1-(v/c)^2}}[/tex]
If you substitute v=(99/101) * c in the above expression, you get a gamma of 5.05.
This checks - B has traveled 2 years, and with a time dilation factor of 5.05, we expect that 2*5.05 = 10.1 years have elapsed on earth. Which is the same result we found earlier.
Hi there,
Thank you for sharing your thoughts and questions about visualizing relativity. I can see that you have a good understanding of the concepts involved, but there are a few things that I would like to clarify.
Firstly, in your scenario, A is not actually stationary. In order for B to be moving away from A at a speed close to the speed of light, A must also be moving at a significant speed in the opposite direction. This is because in relativity, there is no absolute reference frame and all motion is relative. So, in this scenario, both A and B are moving away from each other at close to the speed of light.
Now, let's look at the scenario of B turning around and moving towards A at the same speed. In this case, B is still receiving a red-shifted signal, but it is not the same signal that A originally sent. This is because the signal sent by A has also been affected by time dilation. So, when B turns around and moves towards A, he is actually receiving a new, blue-shifted signal that is being sent by A at the same time that B is moving towards A. This signal will be received by B at a faster pace because B is now moving towards the source of the signal.
To answer your question about whether B will see everything that has happened in fast forward, the answer is no. This is because B's perception of time is different from A's. While B may perceive time as moving faster, it is still moving at a slower pace compared to A. So, B will not see everything in fast forward, but rather at a slightly faster pace than A.
I hope this helps to clarify your understanding of relativity and how information exchange is affected by time dilation and the relative motion of objects. Keep exploring and asking questions, as it is a great way to deepen your understanding of complex concepts like relativity.
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 43 ·
  • · Replies 34 ·
  • · Replies 26 ·
