New Reply
Poisson's equation applied to an integral
Share Thread Thread Tools
Feb29-12, 11:52 AM   #1
This is not a homework problem, but a math question of curiosity. At 57 I am way past courses and homework.
If a potential, V, is expressed as a volume integral, how does one apply Poisson's equation to that integral?
If V = k∫V'[itex]\frac{ρ}{R}[/itex]dv' (V on the LHS is voltage and the integral on the RHS is the integral over V', the volume.)
how do I manipulate Poisson's, i.e., [itex]\nabla[/itex]2V = -[itex]\frac{ρ}{ε}[/itex]?
I cannot find enough in my various calculus books to figure this out. A web site reference would be fine.
Thanks.
Thomas
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Feb29-12, 12:44 PM   #2
Recognitions:
It's not such an easy question as it might seem. The most elegant way is to use functional analysis and the theory of distributions. You look for the Green's function of the Laplace operator,
[tex]\Delta_x G(\vec{x},\vec{x}')=\delta^{(3)}(\vec{x}-\vec{x}').[/tex]
First of all it's clear from the symmetries of the problem that
[tex]G(\vec{x},\vec{x}')=g(|\vec{x}-\vec{x}'|).[/tex]
Setting [tex]\vec{y}=\vec{x}-\vec{x}'[/tex] leads to
[tex]\Delta_y g(|\vec{y}|)=\delta^{(3)}(\vec{y}).[/tex]
Now you introduce spherical coordinates for [itex]r=|\vec{y}| \neq 0[/itex]. This leads to
[tex]\frac{1}{r} [r g(r)]''=0.[/tex]
This you can solve by succesive integration
[tex]g(r)=\frac{C_1}{r}+C_2,[/tex]
where [itex]C_{1,2}[/itex] are integration constants. Since we seek for the solution, which vanishes at infinity, we have [itex]C_2=0[/itex]. The constant [itex]C_1[/itex] has to be found by the defining equation. To that end you integrate the equation
[tex]\Delta g(|\vec{y}|)=\delta^{(3)}(\vec{y})[/tex]
over a sphere around the origin with arbitrary radius. For the right-hand side you get [itex]1[/itex], and for the left-hand side you use Gauß's integral theorem
[tex]\int_{K} \mathrm{d}^3 \vec{y} \Delta g(|\vec{y}|) = \int_{\partial K} \mathrm{d}^2 \vec{F} \cdot \vec{\nabla} g(|\vec{y}|).[/tex]
You easily find
[tex]\vec{\nabla} g(|\vec{y}|)=-C_1 \frac{\vec{y}}{|\vec{y}|^3},[/tex]
and the surface integral thus gives
[tex]-4 \pi C_1=1 \; \Rightarrow \; C_1=-\frac{1}{4 \pi}.[/tex]
So we have
[tex]G(\vec{x},\vec{x}')=-\frac{1}{4 \pi |\vec{x}-\vec{x}'|^3}.[/tex]
Thus the standard solution for Poisson's equation is
[tex]V(\vec{x})=-\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' G(\vec{x},\vec{x}') \frac{\rho(\vec{x}')}{\epsilon}=\frac{1}{4 \pi \epsilon} \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{|\vec{x}-\vec{x}'|^3}.[/tex]
Mar1-12, 03:45 AM   #3
Recognitions:
I don't know, how to edit postings in this forums, so here is an erratum to my previous one. The end of the posting must read:
So we have
[tex]G(\vec{x},\vec{x}')=-\frac{1}{4 \pi |\vec{x}-\vec{x}'|}.[/tex]
[tex]V(\vec{x})=-\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' G(\vec{x},\vec{x}') \frac{\rho(\vec{x}')}{\epsilon}=\frac{1}{4 \pi \epsilon} \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{|\vec{x}-\vec{x}'|}.[/tex]
New Reply
Tags
integral, laplacian, poisson's
Thread Tools
Similar Threads for: Poisson's equation applied to an integral
Thread Forum Replies
Poisson integral formula to solve other integrals Calculus & Beyond Homework 3
Derivation of Poisson's Equation and Laplace's Equation Classical Physics 2
Integral involved in solving Poisson's equation Calculus & Beyond Homework 1
Poisson's equation in 1D Advanced Physics Homework 1
Poisson's Integral Formula for Rectangle having Robin BCs Differential Equations 0
