| New Reply |
Galileo's Acceleration Hypothesis |
Share Thread | Thread Tools |
| Feb29-12, 04:45 PM | #1 |
We rolled a ball down a ramp and timed the time it took to cover a certain distance (15cm, 30cm, 45cm, 60cm, 75cm, 90cm, 105cm, 120cm.) we input the data into a graph (x= time (s^2), y= distance (m)) my partner and I understand that the slope is the 1/2 of the acceleration, but we don't understand how to explain/prove the slope is 1/2 of a. any help would be greatly appreciated! |
| Feb29-12, 06:06 PM | #2 |
Hi FMAgent! Welcome to PF!
![]() have you done calculus yet? |
| Feb29-12, 08:14 PM | #3 |
No, I haven't done calculus, this is my first actual physics course in highschool.
| Feb29-12, 08:19 PM | #4 |
then you're going to want to apply what you have been taught about motion with constant acceleration
for example: do you know the equation x = v0t + [itex]\frac{1}{2}[/itex]at2? |
| Feb29-12, 08:30 PM | #5 |
Yes, so should I explain that d=vit*1/2at^2 is similar to y=mx+b by comparing the variables?
| Feb29-12, 08:32 PM | #6 |
well, y = mx + b is a linear equation, where x = v0t + [itex]\frac{1}{2}[/itex]at2 is a quadratic equation
| Feb29-12, 08:36 PM | #7 |
| Feb29-12, 08:42 PM | #8 |
if we rewrite x = v0t + [itex]\frac{1}{2}[/itex]at2 with x as the variable and y as the independent variable, and then the two constants v0 and a as b and a respectively, we get
y = bx + [itex]\frac{1}{2}[/itex]ax2 so what happens if b (which is the initial velocity) is zero? |
| Feb29-12, 08:45 PM | #9 |
well b is zero, because my Vi is zero, and zero times anything is zero. so if I made distance the y, t^2 the x, then wouldn't 1/2a be my slope? vit being the b but not really nessisary because its zero?
| Feb29-12, 08:49 PM | #10 |
it's not so much that it's not necessary, it's just that it's zero.
And well, what does it look like if we write it like that? |
| Feb29-12, 08:59 PM | #11 |
d= 1/2at^2 + 0
| Feb29-12, 09:06 PM | #12 |
right, so we have two equations
d = [itex]\frac{1}{2}[/itex]at2 y = [itex]\frac{1}{2}[/itex]ax where y = d, and t2 = x the second equation looks like your graph, right? And you know that the first equation is a fundamental equation of constant acceleration, right? so can you see the relationship? |
| Feb29-12, 09:14 PM | #13 |
yes thats the relationship I was looking for.
| Feb29-12, 09:28 PM | #14 |
glad I could help :)
| New Reply |
| Tags |
| acceleration, explanation, galileo, high school physics, slope |
| Thread Tools | |
Similar Threads for: Galileo's Acceleration Hypothesis
| Null hypothesis, alternative hypothesis, statistics! | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Null Hypothesis/Alternative hypothesis, statistics help!! | Engineering, Comp Sci, & Technology Homework | 0 | ||
| advanced relativistic navigation systems | Special & General Relativity | 0 | ||
| Galileo | Introductory Physics Homework | 1 | ||
| Galileo! Galileo! 1989-2003, a Space oddity or Bohemian Rhapsopdy? | General Astronomy | 0 | ||
