Expert Answers for Electronics Questions - Get Help Now!
  • Thread starter Thread starter logearav
    Electronics
This discussion focuses on electronics questions relevant to competitive exams, specifically addressing concepts such as oscillators, input impedance, and Zener diodes. The participant provided answers to various questions, including the assertion that an oscillator requires no input signal and that the output impedance of a transistor is zero. Other topics discussed include the characteristics of UJTs and the frequency output of full-wave rectification. The community is encouraged to verify these answers for accuracy.
  • Understanding of oscillator and amplifier functions
  • Knowledge of input impedance in electronic devices
  • Familiarity with Zener diode characteristics
  • Basic principles of full-wave rectification
  • Research the characteristics and applications of JFET and MOSFET
  • Study the principles of UJT and its operational characteristics
  • Learn about the behavior of Zener diodes under different biasing conditions
  • Explore the design and function of astable multivibrators in circuit applications
Electronics students, competitive exam candidates, and professionals seeking to deepen their understanding of fundamental electronic components and their characteristics.
logearav
Electronics questions -- help needed
Revered members,
I list below some of the questions asked in a competitive exam to test the proficiency of electronics. I request the members to give the answers. I have produced the answers which i have written, below each question. I require your help in ascertaining if they are correct.
An oscillator differs from an amplifier , because it
a) has more gain b) requires no input signal c) requires no DC supply d) always has the same input
Ans: requires no input signal
Which of the following devices has the highest input impedance
a) JFET b) MOSFET C) Crystal Diode d) Ordinary transistor
Ans : Ordinary Transistor
Which of the following is not a characteristic of UJT
a) Saturation Current b) Negative Resistance c) Peak point Voltage d) Bilateral Conduction
Ans : Saturation Current
A zener diode is destroyed if it
a) is forward biased b) is reverse biased c) carries more than the rated current d) carries less than the rated current
Ans : carries more than the rated current
In a full wave rectification, if the input frequency is 50 Hz, then the output has a frequency of
a) 100 Hz b) 50 Hz c) 25 Hz d) 200 Hz
Ans : 50 Hz
The multivibrator which generates square wave of its own is the -------- multivibrator
a) monostable b) astable c) bistable d) tristable
Ans : astable
The output impedance of a transistor is
a) high b) low c) infinity d) zero
Ans : zero
Revered members, I have reproduced the questions verbatim.
You need to explain your thinking behind your responses.
It's a big call to state that the output impedance of anything is zero!
