Working w/ Complex representation E-field
The discussion focuses on the representation of time-varying electric fields (E-fields) in complex format, specifically using the equation \(\vec{E}(t)=E_o e^{\omega t}\cdot\hat{k}\). It clarifies that when calculating the potential from a complex E-field, one does not need to convert to a real representation before taking the gradient. The gradient operation is spatial, while the complex notation, including time-dependent factors like \(e^{i\omega t}\), can be used directly in calculations without modification, ensuring accurate results in accordance with Maxwell's equations.
  • Understanding of electric field representation in physics
  • Familiarity with complex numbers and their applications in physics
  • Knowledge of gradient operations in vector calculus
  • Basic principles of Maxwell's equations
  • Study the application of complex numbers in electromagnetic theory
  • Learn about the gradient operation in vector calculus
  • Explore the implications of Maxwell's equations on time-varying fields
  • Investigate the use of complex notation in other areas of physics
Physicists, electrical engineers, and students studying electromagnetism who are interested in advanced representations of electric fields and their implications in theoretical and applied contexts.
Apteronotus
Often a time varying E-field is represented in complex format. I have a simple E-field (uniform in space) given by
[itex]\vec{E}(t)=E_o\cos(\omega t)\cdot\hat{k}[/itex]
or equivalently, the real part of
[itex]\vec{E}(t)=E_o e^{\omega t}\cdot\hat{k}[/itex].
We know the potential is the negative gradient of the E-field.
If we want to calculate the potential of a field represented in the complex notation, do we need first convert to the "real" representation of and then take the gradient?
In other words how do we deal with all the calculations when the field is represented in the complex format.
Thanks
You have this the wrong way round. The E-field component in a particular direction is minus the gradient in that direction of the potential.
The answer to your question – suitably modified! – is that eiwt can be left in unmodified. It is a time-dependent factor; the gradient operation is a spatial one.
Even when you come across time operators, such as in Maxwell's equations, you can stick with complex notation. The imaginary numbers behave very nicely and you still get the right answer in the end.
