Does RPM affect electricity generation?
The discussion centers on the relationship between RPM (revolutions per minute) and electricity generation, specifically regarding the induced electromotive force (emf) in a coil of wire when a magnet is spun. According to Faraday's law, the induced emf is directly proportional to the rate of flux change, meaning that higher RPM results in greater induced emf. However, the actual current generated depends on the load resistance; with a large load resistance, the current is low despite increased emf, while a small load resistance leads to constant current behavior, minimizing the effect of increased speed on current generation. This principle applies to wind turbines, where higher wind speeds can influence efficiency.
  • Understanding of Faraday's law of electromagnetic induction
  • Knowledge of electromotive force (emf) and its relationship to current
  • Familiarity with load resistance concepts in electrical circuits
  • Basic principles of wind turbine operation and efficiency
  • Study the mathematical equations related to Faraday's law of induction
  • Research the impact of load resistance on current generation in electrical circuits
  • Explore the efficiency factors affecting wind turbine performance
  • Learn about the differences between constant voltage and constant current behavior in induction systems
Electrical engineers, renewable energy researchers, and anyone involved in the design and optimization of generators and wind turbines will benefit from this discussion.
Ralphonsicus
Let's say I have a magnet inside a coil of wire. If I spin the magnet for a 10 second period, twice, the second time spinning it significantly faster, will more current be induced during the second period?
And would this apply to generators in wind turbines, etc.?
Thanks.
Thanks.
If you mean the induced "emf" is higher, you are right. According to Faraday's low, the induced emf is proportion to the rate of flux change. Higher speed, faster change of the flux. The current, however, depend on the load. If you have a resistive load and it is fixed, the current is proportional to the emf.
Yes this applies to wind generators too, but more wind power is required then and it may affect the efficiency of the win turbine.
Yes and no. If the loading resistance is very large, then the induction exhibits "constant voltage" behavior. The induced emf varies with the speed/rpm. The current is the induced voltage divided by the loading resistance, again as long as Rload is relatively large. A large loading resistance results in a load current that is small, and consequently this small load current has a small magnetic field which is oriented with a polarity opposite that of the magnet. A small current and small magnetic field provides very little decrease in the overall magnetic flux.
But if the loading resistance is quite small, the induction exhibits "constant current behavior". In this instance, increasing speed has little effect on the induced current. I posted the equations for this type of problem recently. Maybe a search will turn it up. BR.
Claude
