How Is Induced Current Calculated in a Moving Bar Near a Wire?
The discussion focuses on calculating the induced current in a moving bar near a vertical wire carrying a steady current of 17 A. The setup involves a pair of horizontal rails spaced 0.2 m apart, connected by a 7.6 Ω resistor. The bar moves at a constant velocity of 0.5 m/s and is positioned 0.18 m from the wire. The calculated induced current is 0.201 µA, derived from the induced electromotive force (emf) of 1.53 µV using the formula I = ε / R.
  • Understanding of electromagnetic induction principles
  • Familiarity with the Biot-Savart Law for magnetic field calculations
  • Knowledge of Ohm's Law for current and resistance calculations
  • Basic understanding of magnetic flux and its relation to induced emf
  • Study the Biot-Savart Law for calculating magnetic fields around current-carrying wires
  • Learn about Faraday's Law of Electromagnetic Induction
  • Explore the concept of magnetic flux and its role in induced emf calculations
  • Investigate practical applications of induced current in electrical engineering
Students and professionals in physics and electrical engineering, particularly those interested in electromagnetic theory and applications of induced current in circuits.
Lizziecupcake
Problem: A long vertical wire carries a steady 17 A current. A pair of rails are horizontal and are 0.2 m apart. A 7.6 Ω resistor connects points a and b, at the end of the rails. A bar is in contact with the rails, and is moved by an external force with a constant velocity of 0.5 m/s as shown. The bar and the rails have negligible resistance. At a given instant t1, the bar is 0.18 m from the wire, as shown. In Figure, at time t1, the induced current in µA is:
Express the answer in three decimal places.
My attempt at the question:
Current in the wire, i = 17 A
Distance between the rails, d = 0.20 m
Resistance, R = 7.6 Ω
Velocity , v = 0.50 m/s
At time t1, the bar is 0.18 m from the wire
B = μ0 i / 2 π d
= (4 π *10-7 T.m/A) (17 A) / 2π (0.20 m)
B = 1.7 *10-5 T
Induced emf , ε = dφ / dt
= B L v
= (1.7 *10-5 T) (0.18 m) (0.50 m/s)
= 1.53 *10-6 V
Induced current, I = ε / R
= (1.53 *10-6 V) / (7.6 Ω)
= 2.01 *10-7 A
= 0.201 μ A
It seems to be wrong so I don't exactly know what I'm doing wrong so could someone help me out?
I'm still trying to get my head round the set-up. It sounds as though the bar, rails and resistor make a rectangle which is perpendicular to the vertical wire with steady current. Is this right? But in this case, the vertical wire would create a magnetic field which is not perpendicular to the rectangle. So the magnetic flux would be zero, at all times... But it seems unlikely that the answer would just be zero, so I think I have misunderstood the set-up somehow.
cupcake, you said some figure is there. figure will help
