Register to reply
Which compound is more acidic? (without using pkA value) HCl or H2SO4
by Kaede_N9
Tags: acidic, compound, h2so4
Share this thread:
Kaede_N9
#1
Mar8-12, 07:55 PM
P: 11
HCl or H2SO4
2. Relevant equations
Electronegativity.
Inductive effect.
3. The attempt at a solution
Since sulfur is more electronegative compared to cholrine, H2SO4 is more acidic than HCl...
So then I think of how I could use inductive effect instead of electronegativity to verify this claim.
Since sulfur is more electronegative compared to oxygen it shall pull away electrons slightly, more than chlorine on hydrogen?
I don't think it'll work since there are a 3 oxygens around sulfur and so the combined electronegativity outweighs that of sulfur?
What do you think?
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
Borek
#2
Mar9-12, 01:34 AM
Admin
Borek's Avatar
P: 23,597
I think I have no idea what it means to be "more acidic". And I am deadly serious, I am not aware of any definition of acidity. The way I see it it can mean one of two things - acid strength (in which case HCl is "more acidic"), or ability to neutralize base (similarly to alkalinity) - in which case H2SO4 as diprotic is more acidic.
Poorly worded question.
Kaede_N9
#3
Mar9-12, 07:22 AM
P: 11
Original question:
For the following pairs of compounds, predict which one will be the strongest acid
and justify your choice.
Answer:
Between HCl and H2SO4, H2SO4 has a lower pKa (~-9) than HCl (~7) and so it is a stronger acid compared to HCl.
I wanted to answer this question without using a pKa table so I tried comparing the electronegativity of the central atoms, and as wel as their inductive effects. Not sure if inductive effect would work though.
Ygggdrasil
#4
Mar9-12, 10:13 AM
Other Sci
Sci Advisor
P: 1,393
Also consider that resonance stabilization of the conjugate base occurs in H2SO4.
Borek
#5
Mar9-12, 11:26 AM
Admin
Borek's Avatar
P: 23,597
Quote Quote by Kaede_N9 View Post
Apparently it depends on the source used. Kotrly & Sucha (Handbook of Chemical Equilibria in Analytical Chemistry) list sulfuric acid pKa1 as -3, Hulanicki (Reactions of acids and bases in analytical chemistry) lists pKa of HCl as -4.
Register to reply
Related Discussions
A compound differs from an element in that a compound Biology, Chemistry & Other Homework 1
Why are acidic amino acid side chains acidic? Chemistry 4
Is H2SO4 a catalyst? Biology, Chemistry & Other Homework 5
H2SO4 preparation Chemistry 6
