Degrees of freedom of quantum fields and elementary particles
The discussion centers on the degrees of freedom of quantum fields and elementary particles, specifically addressing photons, electrons, and W and Z bosons. A photon possesses two degrees of freedom corresponding to its two polarization states, while an electron also has two spin states. The degrees of freedom extend beyond energy and momentum, with free particles having additional quantities related to their momentum directions and total energy. The concept of degrees of freedom is linked to the quantum numbers of particles, which can vary based on how particles are defined, particularly in the context of symmetries.
  • Understanding of quantum mechanics principles
  • Familiarity with particle physics terminology
  • Knowledge of quantum numbers and their significance
  • Basic grasp of symmetries in physics
  • Research the concept of quantum numbers in particle physics
  • Study the properties and behaviors of W and Z bosons
  • Explore the implications of symmetries in quantum field theory
  • Learn about the relationship between energy, momentum, and mass in quantum mechanics
Physicists, students of quantum mechanics, and anyone interested in the fundamental properties of elementary particles and their quantum fields.
Lapidus
They say that a photon has two degrees of freedom, its two polarization states.
Does that also mean that the electron has only two degrees of freedom, its two spin states?
What about the frequency of a photon, is that not a degree of freedom? Or the three space directions that a electron can travel? What mans degree of freedom anyway when referring to elementary particles and its quantum fields?
thanks
These degrees of freedom are those over and above those of energy/momentum. For free particles, the latter give three additional quantities (three directions of momenta plus the total energy but minus one because of the relationship between total energy, total momentum and the particle's mass).
An electon does also have only two possible spin states, though this arises from different equations than those which govern photons. By contrast, W and Z bosons each have three polarisation states as they are massive.
In general the degrees of freedom correspond to whatever quantum numbers the particle has. In some cases this depends on what you define as being the 'same' particle. For example, if you define an up quark generically as a single particle then it has three colour states, whereas if you define uR, uB and uG as separate particles then obviously they don't indiviudally have that particular freedom. The former approach itends to be used when considering symmetries, particularly unbroken ones such as the colour states of quarks or spin polarisations. It's important to be clear what one is doing.
