Newtonian Mechanics:friction, tension and acceleration
The discussion focuses on a physics problem involving three connected masses (m1 = 4.00 kg, m2 = 1.00 kg, m3 = 2.00 kg) on a table with a coefficient of kinetic friction of 0.350. Key equations used include F=ma and F(kinetic friction)=μkf x F(n). The calculated acceleration for m1 is 3.7465 m/s², while the relationship between tension and friction is debated, concluding that tension remains constant regardless of changes in the coefficient of friction (μkf).
  • Understanding of Newton's laws of motion
  • Knowledge of free-body diagrams
  • Familiarity with kinetic friction concepts
  • Ability to solve equations involving forces and acceleration
  • Study the derivation of free-body diagrams for connected masses
  • Learn about the effects of friction on tension in pulley systems
  • Explore advanced applications of Newton's laws in multi-body systems
  • Investigate the role of normal force in friction calculations
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of problem-solving in dynamics involving friction and tension.
Plebert
Alright, the problem is as follows:Three objects are connected on a table. The coefficient of kinetic friction between the block of mass m2 and the table is 0.350.The other two masses are hanging perpendicular to the tabletop, suspended by wires on opposite sides of the table.From left to right, the objects have masses of m1 = 4.00 kg, m2 = 1.00 kg and m3 = 2.00 kg, and the pulleys are frictionless.
(a) Draw free‐body diagrams of each of the objects. (b)
Determine the acceleration of each object and their directions. (c) Determine the
tensions in the two cords. (d) If the tabletop were smooth, would the
tensions increase, decrease or stay the same?
These are the equations I've assumed to be relevant as none are given.
F=ma
F(n)=m2xg
F(gravity)=mg
ƩF(m1)=((m1xg)-((μkf x(m2xg))+(m3xg)))
Well, for part (a) I can't really show you my free body diagrams, but I can tell you I derived this---->ƩF(m1)=((m1xg)-((μkf x(m2xg))+(m3xg)))
from drawing the forces associated with the mass.
When all relevant values are substituted in ended up with a net force of 14.985N In the positive "down" direction. Which when rearranged into the form
a=f/m
yields, a=3.7465m/s^2
for m1
I'm finding mass 2 much harder to model, I am not sure what role friction plays in defining the normal component of the reactionary force
for part c)
I'm assuming the tension in the wires is the Ʃf(x)
which would look something like, Ʃf(x)=(m1xg) + (m3xg) ?
I've never seen a relationship linking friction and tension...
so, is the tension independent of the friction? If so,this would mean the only forces causing tension are (m1xg) + (m3xg)
For part d) If I'm right in my above assertion, the tension would remain constant regardless of changes in μkf.
I know this question shouldn't be so complicated, but I'm just having trouble getting my head around everything.
Any help is priorly appreciated.
I don't understand how you got this from analyzing mass 1. Looks like you have forces acting on the other masses mixed in.
Start by identifying the forces acting on each mass.
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 38 ·
