| New Reply |
Which letter point shows the highest point of pressure in this conjoined container? |
Share Thread | Thread Tools |
| Mar12-12, 03:14 AM | #1 |
In this conjoined container, water is filled up to the top at all three openings. Which letter point shows the highest point of pressure in this conjoined container? ````/~\``````````|~~~|`````\~~~~~~~/ ``` /~~\`````````|~~~|``````\~~~~~~/ ```/~~~\````````|~~~|```````\~~~~~/ ``/~~~~\````````|~~~|```````\~C~~/ `/~~`A~~\_______|~B~|________\~~/ /_____________C__________________/ Key: ~ represents water ` ignore, represents space (used to post on forum) 2. Relevant equations Pascal’s law, Pressure = Force/Area 3. The attempt at a solution I think point C has the highest pressure point because two forces act on it from left to right and right to left. However, the pressure equilibrium comes to play and I am unsure which point displays the highest point of pressure. My second guess would be point C due to the higher force pushing downwards. What is the right answer? Thanks. |
| Mar12-12, 05:20 AM | #2 |
hi brainst0rm! welcome to pf!
![]() i'm confused |
| Mar12-12, 10:43 AM | #3 |
Oops. I revised the data points with one point C and one point D.
Which letter point shows the highest point of pressure in this conjoined container? 1. The problem statement, all variables and given/known data In this conjoined container, water is filled up to the top at all three openings. Which letter point shows the highest point of pressure in this conjoined container? ````/~\``````````|~~~|`````\~~~~~~~/ ``` /~~\`````````|~~~|``````\~~~~~~/ ```/~~~\````````|~~~|```````\~~~~~/ ``/~~~~\````````|~~~|```````\~C~~/ `/~~`A~~\_______|~B~|________\~~'/ /_____________D__________________/ Key: ~ represents water ` ignore, represents space (used to post on forum) 2. Relevant equations Pascal’s law, Pressure = Force/Area 3. The attempt at a solution I think point D has the highest pressure point because two forces act on it from left to right and right to left. However, the pressure equilibrium comes to play and I am unsure which point displays the highest point of pressure. My second guess would be point C due to the higher force pushing downwards. What is the right answer? Thanks. |
| Mar12-12, 11:56 AM | #4 |
Which letter point shows the highest point of pressure in this conjoined container?(i don't even understand the reason… pressure acts left right and all around everywhere )the pressure in a liquid is ρgh (+ atmospheric pressure) … are you not familiar with that formula? |
| Mar12-12, 04:04 PM | #5 |
Oh yes, P = pgh. How about this?
P = pgh, or Pressure = (Density) x (gravity due to acceleration) x (height). Because all points share the same density and gravity due to acceleration, the highest pressure point would be the point with the largest height, which is Point D. |
| Mar12-12, 05:46 PM | #6 |
hi brainst0rm!
![]() the shape of the container doesn't matter … so long as it's open to the atmosphere, the pressure only depends on the depth
| New Reply |
| Tags |
| pressure, pressure difference, pressure equilibrium, pressure forces |
| Thread Tools | |
Similar Threads for: Which letter point shows the highest point of pressure in this conjoined container?
| highest boiling point | Biology, Chemistry & Other Homework | 4 | ||
| Highest point an object can travel? | General Physics | 11 | ||
| Acceleration at its highest point? | Advanced Physics Homework | 5 | ||
| highest point | Introductory Physics Homework | 2 | ||
| highest point of trajectory | Introductory Physics Homework | 5 | ||
