Parsing arguments to a python file
  • Context: Python
  • Thread starter Thread starter magistros
    File Python
The discussion revolves around how to pass arguments to a Python script, specifically within the context of using CMS_SW. Participants explore methods for handling input files in Python scripts and express challenges encountered during implementation.
  • Technical explanation, Homework-related, Debate/contested
  • One participant seeks assistance on how to declare input files in a Python script when using the command "cmsRun script.py file.root".
  • Another participant suggests using the sys module to access command-line arguments, providing a basic code snippet for opening the input file.
  • A different participant mentions the argparse module as a potential solution for handling command-line arguments, indicating it may be useful depending on the complexity of the needs.
  • A participant reports an error encountered when attempting to run the script, suggesting that CMS_SW may not support Python as expected.
  • Another participant notes that they encountered an issue with the argparse module being missing and expresses a decision to switch to C++ for their implementation.
Participants express differing experiences and challenges with the Python implementation, and there is no consensus on a definitive solution. Some participants propose methods while others report failures or limitations.
Limitations include potential misunderstandings about the capabilities of CMS_SW regarding Python, as well as issues with missing modules like argparse that may affect the proposed solutions.
magistros
Dear forum,
I would like you to help me on .py scripts.
I am using CMS_SW and I want to do something like this:
where "file.root" is the file that the .py script needs to run... But I cannot find, how I declare it to the .py code...
these .py files, are configuration files...
thank you in advance!
Technology news on Phys.org
Try it like this:
Code:
import sys
cmd=sys.argv
filename=cmd[1]
infile = open(filename, 'r') # Now do what you want with the file
Depending on the complexity of your needs, you may want to look at the argparse module.
Dear phyzguy,
I tried it but I get this error
cms::Exception caught in cmsRun
---- Configuration BEGIN
FailedInputSource Configuration of primary input source has failed
---- Configuration END
Maybe the CMS_SW does not run python but something like this...
Dear jhae2.718,
I tried the argparse and it says that the argparse is missing...
Anyway, I will make it in C++..
Thank you for your time guys!
  • · Replies 17 ·
17K
