| New Reply |
Fusion with help of accelerators? |
Share Thread | Thread Tools |
| Mar13-12, 11:04 PM | #1 |
Is it possible to use neutral beam accelerators to smash deuterium atoms at each other to acheive practical fusion?
| Mar14-12, 12:53 AM | #2 |
This was actually one of the first fusion experiment. The latest attempt was SIGFE at the University of Wisconsin, Madison. It was a failure; the results indicated that the neutron production was from Fe(D,2n) spallation rather than fusion. Plenty of Neutrons, though - best neutrons/Watt from any device.
| Mar14-12, 08:31 AM | #3 |
It means just neutral atoms.Neutral beam injectors are used as plasma heaters in TOKAMAK devices.Could we make something that works like MHD generator in reverse? We could slightly ionize deuterium vapour just to make it conductive.And after speed it up with help of electrostatic accelerator. What speeds could we attain in this way? |
| Mar14-12, 03:37 PM | #4 |
Fusion with help of accelerators?If you don't ionize them then they don't accelerate... |
| Mar14-12, 04:18 PM | #5 |
works without any ionization?Maybe small ionization is sufficient? |
| Mar14-12, 06:43 PM | #6 |
| Mar14-12, 08:06 PM | #7 |
There already exist some storage rings which designed for neutral atoms. http://accessscience.com/content/Neu...-ring/YB050460 I guess if it could be stored then it could be accelerated too. |
| Mar14-12, 08:40 PM | #8 |
| Mar14-12, 08:50 PM | #9 |
See http://lss.fnal.gov/archive/2005/pub...-05-094-ad.pdf Bob S |
| Mar15-12, 05:21 PM | #10 |
| Mar15-12, 06:17 PM | #11 |
Admin
In order to magnetically confine a gas, one needs ions, either + or -. Usually this entails a fully ionized gas or plasma. In fusion plasmas, one has mixtures of ions (deuterons, tritons, 3He2+, . . . .) and electrons. Fusion reactions occur among the bare nuclei (ions), while the electrons scatter about wasting energy (brehmsstrahlung, cyclotron radiation, recombination, etc). Neutral atoms leak through magnetic fields.
Neutral beams are used to feed and heat a plasma because neutral atoms move through magentic fields. Once in a plasma, neutrals collide with other neutrals, ions or electrons and become ionized. Nature favors neutrality, and plasmas are quasi-steady-state, because without energy input, they would tend to become a neutral gas. Ideally, a fusion plasma develops enough fusion energy to maintain the plasma AND generate surplus energy that can be extracted as thermal energy or electric current IF the charges can be separated and recombined across a load (direct conversion). |
| Mar17-12, 10:23 PM | #12 |
What do you think the most perspective direction in fusion power research up to date?
Something that is cheap to implement and quite simple? |
| Mar18-12, 12:28 AM | #13 |
| Mar18-12, 02:16 PM | #14 |
And why it going to be cheap?As I know it would still require to have superconducting magnets to create strong enough magnetic field.And vacuum.So why is it going to be cheap? |
| Mar18-12, 03:53 PM | #15 |
| Mar18-12, 05:14 PM | #16 |
Why Polywell is going to be cheaper than Tokamak?
| Mar18-12, 09:38 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Fusion with help of accelerators?
| is General Fusion and Magnetized target fusion legit? | Nuclear Engineering | 16 | ||
| Circular accelerators vs Linear Accelerators | General Physics | 5 | ||
| Standing Wave Accelerators Vs Travelling Wave Accelerators | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Accelerators and fusion of elements | Atomic, Solid State, Comp. Physics | 5 | ||
| Why not particle accelerators for fusion? | Nuclear Engineering | 19 | ||
