New Reply
Find the volume of the region bounded by x^2+(y-1)^2 = 1 rotated about the x-axis.
Share Thread Thread Tools
Mar14-12, 11:40 PM   #1
1. The region bounded by the given curves is rotated about the specific axis. Find the volume of the resulting solid by any method (disc or shell).
2. x^2 + (y-1)^2 = 1
3. This is my first time posting up a homework question, so I apologize if I didn't get the notation down correctly or something.
I tried shells and ended up with ∏ as my answer. (I hope that's a pi symbol.)
V= 2(2∏radius)(width) I doubled the circumference to get the whole circle rather than just having the semi-circle.
V = 4∏ ∫y sqrt[ 1- (y-1)^2] dy on [0,2]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar15-12, 12:20 AM   #2
The two dimensional figure is definitely a circle which passes through the origin. The rotation about x axis would make it a horn torus (that's a funny name actually).
Using the formula that I remember (it's derived using integration, plus looks obvious if you see)
V = (π(r^2))(2πR)
Now putting r=1 and R=(1/2)
V=(π(1))(π)
So my answer would be π^2
I might me miserably wrong though.
Mar15-12, 12:40 AM   #3
Mentor
Quote by sushifan View Post
You doubled the width from x = 0 to x = +√(1 - (y - 1)2).
Also, your volume formula needs something for the thickness of the shell, which in this case is Δy.
Mar15-12, 12:44 AM   #4
I got [0,2] in regards to the y-axis, not the x-axis, which is [0,1]. My mistake, sorry!
I'll retry what I did but on [0,1] this time.
Mar15-12, 12:47 AM   #5
Mentor
No, [0, 2] is the right interval along the y-axis. I took that comment out right after I posted it, but I was a bit too slow.
Mar15-12, 12:53 AM   #6
Quote by Mark44 View Post
Oh, okay. I'm not sure what action I should take now. But was my mistake the doubling part?
Actually, when I integrate there's one part in which I do substitution and the upper limit and lower limit became the same, so that part of my integral equaled 0. I thought that maybe that accounted for the "empty space". Maybe I should type out my whole solution...I'll do that now.
Mar15-12, 01:02 AM   #7
Mentor
Yeah, show what you did. The integral is not amenable to an ordinary substitution, I don't believe.
BTW, wolfram alpha says the value is 2π2, so I'm not sure I trust cng99's formula.
Mar15-12, 01:10 AM   #8
V = 4∏ ∫ y sqrt[1-(y-1)^2] dy on [0,2]
Substitution: u = y - 1 → du = dy
V = 4∏ ∫ (u+1) sqrt(1-u^2) du on [-1,1]
V = 4∏ ∫u sqrt(1-u^2) du + 4∏ ∫ sqrt(1-u^2) du on [-1,1]
The left integral:
Substitution: t = 1-u^2 → dt = -2du
V = -2∏ ∫ sqrt(t) dt on [0,0] so that just equals 0
The right integral:
Substitution: u = sin∅ → du = cos∅ d∅
V = 4∏ ∫ sqrt[1-sin^2∅] cos∅ d∅ on [arcsin(-1),arcsin(1)]
V = 4∏ ∫ cos^2∅ d∅ on [arcsin(-1),arcsin(1)]
V = 4∏ ∫ 1/2 [1+cos2∅] d∅ on [arcsin(-1),arcsin(1)]
V = 4∏ [ 1/2∅ + 1/4 sin2∅] on [arcsin(-1),arcsin(1)]
V = 4∏ [ 1/2 * ∏/2 + 1/4 * 0] - 4∏ [1/2 * 3∏/2 + 1/4 * 0 ]
V = 4∏ [ ∏/4 - 3∏/4] (Whoops, I just realized my arithmetic mistakes!)
V = -2∏
Okay...so sorry about that. ∏ was not my original answer! And this is definitely wrong since it's negative....
Mar15-12, 01:15 AM   #9
Yeah, I don't understand it at all.
And ohhh, so π is pi!
Mar15-12, 01:28 AM   #10
So...does anyone have advice for my solution?
Mar15-12, 01:59 AM   #11
What's the answer given in the book?
Mar15-12, 02:19 AM   #12
Quote by cng99 View Post
There's no answer provided in the book since this is an even numbered problem. But someone on a different forum told me the answer should be 2π^2. He used Theorem of Pappus, though, and I'm limited to discs and shells.
Mar15-12, 02:36 AM   #13
Of course!!!
It's 2π^2
Volume = (2πR)(πr^2)
http://whistleralley.com/torus/torus.htm
And in this case R=1, r=1.
Why do you wanna do integration?
Mar15-12, 02:48 AM   #14
Of course!!!
It's 2π^2
The problem's instructions says that I can only use discs or shells, so I have to use integration. Pappus is off limits, especially since I never learned it.
Mar15-12, 03:54 AM   #15
Bump......
Mar15-12, 08:40 AM   #16
Mentor
The left integral:
The right integral:
V = -2∏
I don't have time to go through this right now, but I don't see anything obviously wrong in your approach. One suggestion is to just work with indefinite integrals (no limits of integration), and then evaluate your final antiderivative at the original limits of integration, 0 and 2. It could be that a small error in switching several times to different limits of integration might have caused your error.
BTW, bumping a thread before 24 hours have passed is not permitted here at PF.
Mar15-12, 09:16 AM   #17
Why don't you just use the disk method (well washer I guess) on the top portion of the arc.
For example:
X2+(y-1)2=1 Becomes:
y=+/-sqrt(1-x2) + 1
We just revolve the top arc around y=1 and multiply by 2.
So:
2[itex]\pi[/itex]∫[itex]^{1}_{-1}[/itex] R(x)2 - r(x)2dx
R(x) = sqrt(1-x2) + 1
r(x) = 1 (revolving about y=1)
R(x)2-r(x)2 = (1-x2) + 2 sqrt(1-x2)
So now we have:
2[itex]\pi[/itex]∫[itex]^{1}_{-1}[/itex] (1-x2) + 2sqrt(1-x2)dx
Splitting that into two integrals you get 8[itex]\pi[/itex]/3 for the first and
the next integral 2[itex]\pi[/itex]∫[itex]^{1}_{-1}[/itex] 2sqrt(1-x2)dx needs to be done with trig substitution...
New Reply
Tags
volume circle
Thread Tools
Similar Threads for: Find the volume of the region bounded by x^2+(y-1)^2 = 1 rotated about the x-axis.
Thread Forum Replies
Find the moment of inertia (about z axis) of region bounded by a parabloid and plane Calculus & Beyond Homework 0
Use the shell method to find the volume of the rotated region... Calculus & Beyond Homework 5
Omg, this is driving me CRAZY! Volume of a rotated region on a graph. Calculus & Beyond Homework 0
ln(x) rotated around the x-axis [1,4] Find Volume Calculus & Beyond Homework 2
