New Reply
Calculating Is and nVt for Silicon Diode, How?
Share Thread Thread Tools
Mar15-12, 04:08 AM   #1
Hello, everyone!
I was asked by my lab instructor for an Electronic course to conduct a diode experiment by which I can get the value of (nVt) and saturation current (Is) for that diode.
I did the experiment by connecting a DC power supply in series with a forward-biased silicon diode (1N4007-MIC), and a 1Kohm resistor. I took voltage reading across the diode starting from 10V DC supply, down to 1V. Now, I have the readings, plus I calculated the diode current (ID) for each -1V difference in DC supply. Also, I graphed a curve of I-V characteristics.
Well, I understand that to get the value of nVt and Is, I have to take two values on that curve, an upper value of VD(V2) on the horizontal axis corresponding to an upper value of ID(I2) on the vertical axis, and a lower value of VD(V1) corresponding to a lower value of ID(I1). I take these values and substitute in the equation:
V2-V1=2.3nVt log(I2/I1) --> From this, I can calculate the only unknown value which is nVt.
I take the resulting value and substitute in the equation:
I=Is e^(V/nVt) --> From this, I can calculate the only unknown value which is Is.
So, my question is, is my understanding to how to get the two values correct? is there any shorter and easier way to get them?
Also, where can I find the the two values in the diode's datasheet? I looked up for it but didn't find any indication of it (this datasheet for example).
Thanks.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Mar15-12, 09:41 AM   #2
Recognitions:
Homework Helper Homework Help
Hi CDTOE!
Quote by CDTOE View Post
It looks fine. Take more than just 2 readings off the graph, and determine an average of your nVt estimates.
You might have to deduce them from the typical V-I curve provided?
New Reply
Thread Tools
Similar Threads for: Calculating Is and nVt for Silicon Diode, How?
Thread Forum Replies
Potential barrier of Silicon Diode Introductory Physics Homework 2
dc resistance of silicon diode Engineering, Comp Sci, & Technology Homework 1
Questions about Silicon Diode Detectors Electrical Engineering 0
Zener Diode: germanium vs. silicon Electrical Engineering 11
I-V characteristics of a silicon p-n junction diode Electrical Engineering 2
