| New Reply |
Strange behaviour of viscoelastic materials |
Share Thread | Thread Tools |
| Mar15-12, 07:53 AM | #1 |
Dear Physics Forum,
I posted this in the Mechanical Engineering Forum a while ago without any responses, but by looking at the other threads I suspect that it was the wrong place so Im posting it again here where it looks more at home (so apologies if i was wrong!). Can anyone explain why viscoelastic materials behave differently at different strain rates? I understand the general explanation that the behaviour of viscoelastic materials is governed by a solid phase (elastic) and a fluid phase (viscous) and that at higher strain rates the elastic behaviour dominates while at lower strain rates the viscous effects dominate... however im having trouble translating this into meaningful physical behaviour! I am particularly interested in the uniaxial compression of a bulk solid to a constant level of strain (the stress relaxation behaviour): my results show that at higher loading velocities, im seeing a more rapid decay of the force response then at lower loading velocities. This means that after x amount of time, there is a higher reaction force in the slowly compressed test then in the faster compressed test (both subjected to the same load). By looking at the curves, the lower strain rates produce greater degrees of damping i.e. flatter curves, then those produced by high strain rates. In fact, when trying to use a two parameter power function to fit the data, it works well for the higher loading velocity, but not very well at all at the lower velocities (which suggests different mechanisms are at play)! Does a function exist that can be used on both low and high strain rates for such materials? Does anyone have any experience with modelling viscoelastic materials? Ive done some research and managed to find two papers reporting similar behaviour (but no attempt at explanation!) using polymers or organics fruits... Maybe this is an agreed characteristic of a viscoelastic material which does not need explaining in scientific journals... either way my research has failed to help me on this one... Can anyone help? Any ideas would be much appreciated! |
| Mar15-12, 08:56 AM | #2 |
Recognitions:
As to your second sentence, that appears to be a measurement of creep? Creep requires irreversible thermodynamic considerations and is not viscoelasticity. OTOH, you may have some luck looking into hypo-elasticity. |
| New Reply |
| Tags |
| regression analysis, strain rate effect, viscoelastic |
| Thread Tools | |
Similar Threads for: Strange behaviour of viscoelastic materials
| Strange behaviour of viscoelastic materials | Mechanical Engineering | 0 | ||
| Maxwell model of viscoelastic behaviour - Derivation of governing equation | Materials & Chemical Engineering | 3 | ||
| IR stereo remote strange behaviour | General Discussion | 12 | ||
| (Spivak) - a function with strange behaviour. | Calculus | 11 | ||
