Can We Pair Composition of Velocities with an Expanding Universe?
The discussion addresses the relationship between special relativity (SR) and the expanding universe, specifically how objects can appear to accelerate away from each other at speeds exceeding the speed of light (c) due to the expansion of space. It is established that while recession velocity can exceed c, the relative velocity between two objects remains sub-luminal when measured locally. The key takeaway is that distance in an expanding universe can increase faster than c, but this does not violate SR because velocity is defined locally, not globally.
  • Understanding of Special Relativity (SR)
  • Familiarity with General Relativity (GR)
  • Knowledge of 4-velocity and 4-vectors
  • Concept of recession velocity in cosmology
  • Study the implications of General Relativity on cosmological models
  • Research the concept of recession velocity and its calculations
  • Learn about the differences between local and global measurements in physics
  • Examine the role of the cosmic microwave background radiation in measuring velocities
Astronomers, physicists, and students of cosmology seeking to understand the interplay between special and general relativity in the context of an expanding universe.
Tibriel
Hi All,
I get that one object can't travel faster than light with respect to another object because of SR and length and time contraction. What I don't get is how this meshes up with expanding universe.
If the space between 2 objects is expanding then wouldn't two objects be accelerating away from each other at a pace which would eventually exceed the speed of light? Yet my understanding of SR says this isn't possible. Does this mean there is a limit to how fast the universe can expand with respect to any observer?
Please help, thinking about this is making my brain short out.
Oh, and I realize the above questions are yes/no questions so if you could also explain that would be helpful.
Thanks!
Velocity addition formula of SR only applies locally in GR, which is required to discuss expanding universe. In GR, there is no unique definition of relative velocity at a distance, so no strong statement can be made.
Instead, different velocities are used for different purposes. Recession velocity (which is based on growth of proper distance between galaxies) can greatly exceed c. On the other hand, if one parallel transports the 4-velocity of one galaxy along its light path to another galaxy, and compare the 4-vectors, you always get a sub-luminal relative speed.
Upshot: your intuition that expanding universe creates a problem for the SR statement is correct.
The distance between two objects in expanding space can increase faster than c, but velocity (relative to the local background radiation) cannot exceed c. That's because distance is a global quantity, and velocity is measured locally. Unfortunately, you can't define velocity as change in global distance over time. It is the change in infinitesmal distance over infinitesmal time, measured between two objects at the same place and time. Kinda makes it hard to actually use for anything.
  • · Replies 35 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 25 ·
