Matter-antimatter symmetry and particle charge
The discussion revolves around the matter-antimatter symmetry problem, particularly focusing on the charge of particles, the classification of electrons and positrons, and the conditions under which annihilation occurs between particles and their antiparticles. It explores theoretical implications and the early universe's particle synthesis.
  • Some participants question why electrons, which are negatively charged, are classified as matter rather than antimatter, suggesting a potential misclassification.
  • There is a discussion about the early universe producing electrons and protons in equal ratios, leading to a net charge of approximately zero, although the reasoning behind this is not fully understood.
  • Participants propose that annihilation occurs only between particles and their own antiparticles, with examples provided (e.g., electron and positron), while questioning the implications of this for matter-antimatter symmetry.
  • Concerns are raised about the unequal amounts of matter and antimatter and whether this is a result of early particle synthesis or later mechanisms affecting particle arrangements.
  • Some participants emphasize the importance of baryon and lepton numbers in understanding the matter-antimatter asymmetry problem, noting that these quantities are conserved in the Standard Model.
  • There is a mention of proton decay producing antiparticles, which complicates the understanding of matter-antimatter dynamics but is framed as not contributing to asymmetry since both baryon and lepton numbers are conserved.
Participants express differing views on the implications of particle classification and the nature of annihilation. While some agree on the conservation of baryon and lepton numbers, the overall discussion remains unresolved regarding the origins and implications of matter-antimatter asymmetry.
Participants acknowledge the complexity of the matter-antimatter symmetry problem, including unresolved assumptions about early universe conditions and the role of specific particle interactions. The discussion highlights the dependence on definitions and the nuances of particle behavior.
Hypatio
If matter composed of quarks of positive charge, and anti-quarks have negative charge, why do we call electrons particles of matter rather than anti-matter?
Is it possible that the matter-antimatter symmetry problem exists because we are actually calling something that is a particle of anti-matter, a particle of matter?
Also, am I correct to assume that annihilation between particles of matter and anti-matter may not occur if they are different types of particles of each. For instance, an electron and positron will annihilate but an electron will not annihilate with another types of anti-matter.
I am probably confused, but I hope someone can critique my thought process.
Well, there is more to being antimatter than simply having a certain charge. But you do raise an interesting question to which I don't really know the answer: why in the early universe were electrons produced in approximately the same ratio as protons, such that the overall charge of the universe is approximately zero, as it more or less appears to be?
I suppose it must be the case that if we assume net zero charge to begin with, then we must end up with either an excess of protons and electrons, or an excess of anti-protons and positrons, but I don't know that we have to make this assumption, except that experimentally it seems to fit the bill and that it is a minimal sort of assumption. Plus I suppose there are nice ideas about the universe being some sort of inflated vacuum fluctuation, and the vacuum has net zero charge.
Well, no, because you would still have a set of particles which behaved (almost) exactly the same as the ones we see around us, yet not know why the universe should have chosen one set over the other.
Yes that is the case. Particles only annihilate with their own antiparticles. They come in pairs, unless they are their own antiparticles (like photons).
Well, if particles only annihilate with their own antiparticles, then if you call a particle like a positron the particle and an electron an anti-particle, then this changes the matter-antimatter symmetry.
The question might be why we have unequal amounts of matter and anti-matter of certain types of particles, while the net energy of anti-particles is the same as particles.
Also, it seems the picture is complicated by the fact that you can get anti-particles from particles, such as in proton decay into a neutron, positron, and a neutrino.
How do we really know then that this is a problem for early synthesis of particles, and not of later mechanisms rearranging things?
I am not quite sure what you are asking here, sorry. Semantics are not important. Perhaps we should try and speak in terms of baryon and lepton numbers. Those are the quantities that we are really talking about, and we want to know why they are not both zero (in the whole universe). In the Standard Model, both baryon number and lepton number are conserved (except for some weird thing about sphalerons that I don't understand, and which have never been observed, although they may have been important in the early universe). So if you move forward past the early universe, the number of baryons minus antibaryons and leptons minus antileptons in the universe is fixed. The numbers that they are fixed to are such that we have loads of protons/neutrons/electrons flying around instead of their antiparticles, and understanding why both these numbers are not zero, and what happened in the early universe to cause this, is the matter/antimatter asymmetry problem.
In this picture both baryon number and lepton number are conserved as the positron and neutrino have opposite lepton number. So nothing weird there. You made some matter and antimatter at the same time, so no asymmetry.
Well, because the Standard Model conserves baryon and lepton number (except for this non-perturbative sphaleron business and perhaps some other exotic things I don't know about), so there are no later mechanisms for rearranging things.
  • · Replies 21 ·
14K
  • · Replies 21 ·
