Railroad diesel engine homework
The discussion revolves around two physics problems involving momentum conservation. The first problem concerns a railroad diesel engine colliding with a freight car, while the second involves a comic-strip character throwing an asteroid and calculating recoil velocity.
  • Mixed
  • Participants explore the application of momentum conservation principles in both scenarios, questioning the setup and calculations. Some express confusion over mass definitions and the implications of coupling masses in the first problem, while others challenge the assumptions made in the second problem regarding initial momentum.
There is an ongoing examination of the mass relationships and momentum equations in both problems. Some participants have offered clarifications on mass definitions, while others are still grappling with the implications of their calculations. Multiple interpretations of the problems are being explored without a clear consensus.
Participants note the importance of understanding the total mass after coupling in the first problem and question the necessity of mass in the second problem. There is also mention of textbook resources being inadequate for some participants.
Imparcticle
A railroad diesel engine weighs four times as much as a freightcar. If the diesel engine coasts at 5km/h into a freightcar that is initially at rest, how fast do the two coast after they couple together?
Given:
m1= 4m2
m2
v1=5km/h
v2=0
unknown : v3
formula:
m1v1+ m2v2=m3v3 (i.e., Total momentum before=total momentum after)
work:
m1v1+ m2v2=m3v3 --> (4 x m2)(5km/h) + (m2)(0)=m3v3
(20km/h)m2=m3v3
answer --> 20km/h=v3
sorry to say that it is incorrect. m3 is the total mass after they have coupled together so m3= 4m2 + m2 = 5m2. cancelling m2 at both sides of the equations you finally get v3 = 4 km/h.
This really must be wrong:
6.) A comic-strip hero Superhuman meets an asteroid in outer space, and hurls it at 800m/s, as fast as a bullet. The asteroid is a thousand times more massive than Superman. In the strip, Superman is seen at rest after the throw. Taking physics into account, what would be his recoil velocity?
Given unknown formula
M1=1000 M2 v3 m1v1+m2v2=m3v3 --> [( m1v1+m2v2)/m3]=v3
V3=800m/s M2
M3 = (1000M2 + M2) v2
V1= 800m/s
Work: [( m1v1+m2v2)/m3]=v3= {[(1000M2)(800m/s)]+[(M2)(v2)]/[(1000M2 +M2)]}=
{[(M2)(800000 kg * m/s) + [(M2)(v2)]/[(1001 M2]}=
{[(800000 kg * m/s) + [(M2)(v2)]/ 1001}=
799 kg * m/s + [(M2 kg * v2)/1001)]
? I don't get this.
how do i know that its the mass after they have coupled together?
V3=800m/s M2
V1= 800m/s
? I don't get this.
You're approaching this question in a wrong way. You are making it more difficult than it really is.
Conservation of momemtum. The system had not momentum at the beginning, which means m1v1+m2v2 = 0.
I really suggest you read your textbook more.
As far as this question goes, why do you need to know the mass?
Imparcticle said:
Given:
m1= 4m2
m2
v1=5km/h
v2=0
m3=m1+m2
=4m2+m2
=5m2
apchemstudent: why? Because of this: m1v1+ m2v2=m3v3
If you're wondering why I asked the question, I was wondering how the quoted person knew "m3 is the total mass after they have coupled together " and not something else.
I did read,but the book isn't good.
never mind on the question. I missed the last part of the question. I've fixed it. thanks anyway.
Leong said:
m3=m1+m2
=4m2+m2
=5m2
thank you very much for your help. :smile:
