Oribtal and rotational velocities
  • Context: Undergrad
  • Thread starter Thread starter mun
    Rotational
The discussion clarifies the distinction between "orbital velocity" and "rotational velocity" in astronomical contexts. Orbital velocity pertains to the speed of individual stars, while rotational velocity refers to the overall motion of galaxies. The equation for rotational velocity includes the term V sin(i), which accounts for the projected component of velocity in the radial direction, whereas orbital velocity does not depend on this term. Understanding these definitions is crucial for interpreting data related to galaxy rotation curves and Doppler shifts.
  • Understanding of basic astronomical concepts, including orbits and rotations.
  • Familiarity with the equations of motion in astrophysics.
  • Knowledge of Doppler shift and its application in measuring velocities.
  • Basic understanding of projection in geometry, particularly in relation to angles.
  • Research the differences between orbital and rotational velocities in astrophysics.
  • Study the implications of rotation curves in galaxy dynamics.
  • Learn about the application of Doppler shift in measuring radial velocities.
  • Explore the mathematical derivation of the V sin(i) term in rotational velocity calculations.
Astronomers, astrophysics students, and anyone interested in understanding the dynamics of celestial bodies and their motion within galaxies.
mun
Hi
Is "orbital velocity" supposed to be the same as "rotational velocity"? it seems that a "rotation curve" is supposed to plot the rotational velocity of a star, but then some articles e.g. http://en.wikipedia.org/wiki/Galaxy_rotation_problem claim "orbital speed" is plotted.
The equation for rotational velocity seems to be in the shape of V sin(i) but the equation for orbital velocity doesn't depend on sin.
Any help will be much appreciated.
Thanks!
Astronomy news on Phys.org
There may be some terminology confusion. Orbital speed refers to individual stars, while rotational velocity refers to the galaxy as a whole.
Hi Mun
I am not sure that there actually is a particularly rigidly defined set of definitions for these terms and I find that they are often used to mean different things. In my experience, 'orbital velocity' and 'rotational velocity' generally mean the same thing when you are discussing an object orbiting another body, i.e. the Earth around the sun, or the sun around the centre of a galaxy. In this case, both terms usually refer to the actual velocities of the orbiting objects, and not the angular velocities (though I suspect it may rarely be used this way).
The term 'rotational velocity' is used in a lot more situations, and usually refers to the velocity of a thing that is rotating around some point. For instance, you may be looking at a frisbee that is spinning: the rotational velocity of some point on that frisbee is its actual velocity.
I do not know where the sin i term comes into all this, but I suspect it has to do with what is normally called 'projected rotational velocity'. That is the component on the rotational velocity in the direction towards or away from us (i.e. in the 'radial direction') and is given by vsini, where v is the actual rotational velocity of the object in question, and i is the angle between our line-of-sight, and the axis around which the object is rotating. For instance, consider the spinning frisbee again. If you look down on the frisbee from above, such that it looks like a circle, the i in vsini is going to be zero, and so the projected rotational velocity of each point on the frisbee is zero, corresponding to the fact that no point on the frisbee is moving towards you or away from you. If you look at the frisbee edge on, such that is looks more or less like a line, i will be 90 degrees, and so vsini with equal v.
This is important in astronomy since the velocities of objects are often measures using Doppler shift, which really measures the 'radial velocity'.
  • · Replies 27 ·
  • · Replies 48 ·
  • · Replies 24 ·
