Rectilinear Motion: Solving for t=0 Velocity
The problem involves analyzing the rectilinear motion of a point Q, which experiences different accelerations over specified time intervals. The task is to determine the initial velocity of Q at t=0, given its position after a series of time intervals and changes in acceleration.
  • Participants discuss the equations of motion for the point Q, considering different time intervals and the effects of acceleration. There are attempts to equate velocity expressions at the transition point of t=5 seconds. Questions arise regarding the correctness of terms in the equations and the interpretation of results.
Participants are actively engaging with the problem, sharing their calculations and questioning each other's reasoning. Some express confusion over the results and seek clarification on specific steps. There is no clear consensus on the correct approach or outcome, as participants explore different interpretations of the equations.
There is mention of a discrepancy between the calculated velocity and the expected answer from a reference source. Participants are also discussing the importance of clearly stating values and maintaining continuity in their calculations.
xzibition8612
A point Q in rectilinear motion passes through the origin at t=0, and from then until 5 seconds have passed, the acceleration of Q is 6 ft/s^2 to the right. Beginning at t=5 seconds, the acceleration of Q is 12t ft/s^2 to the left. If after 2 more seconds point Q is 13 feet to the right of the origin, what was the velocity of Q at t=0?
Assume right is positive and left is negative.
t=0 to t=5
x''=6
x'=6t+(V0)
x=3t^2+(V0)t
From t=5 onwards
x''=-12t
x'=-6t^2+(V1)
x=-2t^3+(V1)t+[75+5(V0)t] (parts in brackets [] obtained by using the x=3t^2+(V0)t equation setting t=5)
we are given 13=-2t^3+(V1)t+[75+5(V0)t] at t=7s (from beginning) or t=2s (considering the equation changes at t=5)
thus plugging in t=2 (since x''=-12t begins at t=5) get:
-46=2(V1)+10(V0)
Now need another equation to solve variables. Equating the equations x'=6t+(V0) (t=0 to t=5) and the equation x'=-6t^2+(V1) (t=5 onwards)
Thus plug in t=5 for x'=6t+(V0) and t=0 for x'=-6t^2+(V1) and then equate them to get
30+(V0)=V1
Solve and get V0 = -8.83 ft/s
Book says answer is 2ft/s to the right.
Something went terribly wrong...
hi xzibition8612! :smile:
hmm :rolleyes: … this is exactly why you should never take short-cuts :redface:
xzibition8612 said:
t=0 to t=5
x''=6
x'=6t+(V0)
x=3t^2+(V0)t
From t=5 onwards
x''=-12t
x'=-6t^2+(V1)
that 5(V0)t should be 5V0, shouldn't it? :wink:
in between those two paragraphs, you should have paused to state explicitly the final values of x and v, that you intend to use later​
Yuo're right. But then I get 2(30+V0)+5(V0)=-46
Hence V0 = -15 m/s
which is still wrong. No idea where i went wrong.
it's very difficult to check your work :redface:
(i don't see a 73 anywhere)
can you write it out in one continuous proof?​
(and please try using the X2 button just above the Reply box, instead of ^ :wink:)
tiny-tim did you get 2 ft/s as the correct answer? If you did, can you just show me how to do it? Because I'm afraid its very difficult to communicate online and if I see what you did then I can figure out where I went wrong thanks.
