Parallel Vs. Series - Capacitance?
The discussion revolves around the reasoning for choosing between parallel and series configurations of capacitors in electrical circuits, particularly in the context of their application in RF circuits and filter designs. Participants explore the implications of capacitance values and the behavior of capacitors in different circuit types, including DC and AC.
  • Some participants note that series capacitors are not commonly used unless part of a filter circuit involving inductors.
  • It is mentioned that the total capacitance in series is calculated differently than in parallel, contrasting with resistors.
  • One participant describes the common practice of using multiple capacitors in parallel to achieve desired capacitance values, especially in RF applications.
  • There is a discussion about the behavior of capacitors in DC versus AC circuits, with some noting that capacitors act as discontinuities in DC and have impedance in AC.
  • Some participants argue about the classification of capacitors in a "T" filter configuration, debating whether they can be considered in series when connected to an inductor.
  • Another participant suggests that series capacitors can be used to allow polarized capacitors to function in AC circuits.
Participants express differing views on the use of series capacitors, particularly in the context of filter circuits. There is no consensus on whether capacitors in certain configurations should be classified as series or not, leading to ongoing debate.
Some statements reflect assumptions about circuit behavior and configurations that may not be universally applicable. The discussion includes unresolved points regarding the definitions and classifications of series and parallel arrangements in specific contexts.
MySecretAlias
What exactly is the reasoning behind deciding to use parallel vs series? What is the value behind capacitance, really, as opposed to a general electric circuit? Thanks.
Normally you wouldn't see series capacitors in a circuit, unless they were part of say a filter circuit that had inductors going from the junction of the two capacitors to ground.
But you wouldn't normally just see two series caps on their own, instead you would just use a smaller value single capacitor.
Remember working out the total values of series and parallel capacitors is opposite to working out the values of series and parallel resistors...
Series resistors add their values... Parallel capacitors add their values.
Now it's very common to see multiple capacitors in parallel specially on RF gear like I work on.
In a RF circuit power supply rails must often be decoupled by multiple capacitors of different values and types so as to keep wide frequency range RF off the power rails.
Eg. You mite have a 10 uF electrolytic or tantalum and a 0.1uF disc ceramic and a 0.001uF disc ceramic ... Just an example of cap use in my world
Cheers
Dave
Vs(DC) ---------||-------- ground
In direct current, electricity cannot flow through a capacitor (it is actually a discontinuity in the circuit).
Vs(~) ---------||-------- ground
In alternating current, the capacitor acts as a kind of resistor (it has an associated impedance).
Which, of course would mean that the caps are NOT in series.
And what does that have to do with the question?
In addition to what davenn pointed out, another reason to use parallel caps is simply to increase the capacitance in the circuit if you don't have a single cap that is big enough.
I can't think of any good reason to put caps in series other than (as a REAL stretch) to end up with a total capacitance that you can't achieve with the capacitors you have on hand by putting them in parallel.
Wellllll... ;) Would almost be tempted to dispute that. Haha.
My thoughts are always in the RF field. I don't do much with filters etc in audio work.
If I have a "T" filter with 2 caps in series and an inductor in parallel from the junction of the 2 caps, for all intents those 2 caps are still in series. How else can we describe it ?
Always willing to learn. :)
Dave
Calling it a T seems quite reasonable. Calling it series caps is just flat wrong and misleading.
If all three of the elements you describe were resistors, would you describe the arms of the T as series resistors? Just flat wrong.
It would be described by a circuit schematic. phinds is correct, the capacitors would not be in series; series elements have the same current because the wire that connects them is not connected to anything else.
EDIT: Another answer to your question: it can be described as a T filter, just as you have done.
A common use of series capacitors is to allow polarised capacitors to work with AC. (Polarised means they have a positive end and a negative end, and these polarities must be respected when connecting the capacitor to any circuit. Electrolytic capacitors are inherently polarised.)
  • · Replies 18 ·
