Laser Cutting for Dense Materials: Q&A
  • Context: Undergrad
  • Thread starter Thread starter boogleboog
    Lasers
This discussion centers on the feasibility of using lasers to cut dense materials, specifically addressing the challenges of achieving a cutting depth of ten feet in materials like rock and steel. The conversation highlights the importance of Rayleigh length, which determines the intensity of the laser beam, and notes that achieving such depth requires a large beam diameter and significant power output, potentially in the megawatt range. The mention of chemical lasers designed for missile destruction suggests that while powerful lasers exist, their application for cutting dense materials remains complex and technically challenging.
  • Understanding of Rayleigh length in laser physics
  • Knowledge of laser power requirements for material cutting
  • Familiarity with chemical lasers and their applications
  • Basic principles of laser-material interaction
  • Research advancements in laser technology for industrial applications
  • Explore the capabilities of chemical lasers in cutting dense materials
  • Investigate ongoing research programs related to laser drilling in oil and gas
  • Learn about the engineering challenges of high-power laser systems
Engineers, researchers, and professionals in materials science and laser technology, particularly those interested in advanced cutting techniques and industrial applications of lasers.
boogleboog
Hi,
Not sure if this is the correct section to post my question, so if not apologies in advance. I'm wondering if there are lasers (need not be for consumer or general manufacturing purposes) that have the capacity to cut up to ten feet depth into dense materials like rock and perhaps some steels? All I have been able to find are engraving level lasers. I do know there is currently a research program studying the potential for using lasers for oil and gas drilling, but I have not been able to find any information on the lasers or where they are in terms of their research.
Any help is appreciated,
Boogleboog
Science news on Phys.org
Too bad Edward Teller died some years ago.
His answer would've certainly been:" Yes! Give me 100 billion dollars and I´ll make it!
Jokes aside, cutting ten feet posses many technical problems. The Rayleigh length is the zone where the laser beam has the highest intensity. Unfortunately, a Rayleigh length ten feet long demands a large beam diameter unless you have an X-ray laser (bring Teller back!). In order to achieve high intensity, this large beam diameter calls for a very large laser power.
Some chemical lasers, designed to destroy missiles, had output power in the mega watt range. I wonder whether this is high enough to cut through ten feet of steel.
Thanks Gordianus,
Unfortunately, for what I have in mind a large diameter would not work. Also, relative to what you mean by 'large' power, that would potentially from a pragmatic standpoint undermine my fantasy tool. Thanks for your reply and the bit of info regarding the Rayleigh length.
  • · Replies 17 ·
