Would a relativistic ship really need much shielding?
A relativistic ship traveling at a Lorentz factor (γ) of 7, equivalent to a velocity of β = 0.99, requires minimal shielding against deep space protons. Calculations indicate that a ship with a cockpit area of 59 m² would encounter approximately 30 protons, resulting in an energy impact of 1.89 x 1011 eV, significantly lower than the energy from a typical dental X-ray, which is around 1027 eV. However, considerations such as cumulative dose over long journeys, interstellar dust, and variations in the density of the interstellar medium must be addressed to fully assess the shielding requirements for extended relativistic travel.
  • Understanding of relativistic physics, specifically Lorentz transformations
  • Familiarity with particle physics, including proton energy calculations
  • Knowledge of interstellar medium properties and densities
  • Basic concepts of radiation dosage and its measurement
  • Research the effects of relativistic travel on shielding requirements for spacecraft
  • Study the properties and density variations of the interstellar medium
  • Examine the implications of cumulative radiation dose over long-duration space missions
  • Explore the impact of interstellar dust on spacecraft integrity and safety
Aerospace engineers, physicists, and space mission planners interested in the safety and design of relativistic spacecraft traveling through deep space.
Albertgauss
Hi all,
It doesn't seem that a relativistic ship traveling in deep space would need much shielding due to particles at rest in the space frame, appearing relativisitc now in the ship's frame. Here's the calculation I did:
Let's imagine a ship the size of a space shuttle traveling with γ of 7 (β = 0.99 ). I assume that when a society can build such a ship, it will be a decent size, comparable to our space shutttle, and use such values therein. I'll approximate the cockpit as a flat circle(normal vector parrallel to direction of travel) with a diameter of 8.7m, for an area of 59 m^2. Now, let's allow 1 proton per m^3 (over estimate) in deep space and sort them in an area of 59 m^2 so that, at a particular time, 30 protons or so will impact the cockpit of our ship. I know that 1 proton per m^3 is a volume density, so making such a number an area density is, again, an overestimate.
In the ship's frame, the ship will be at rest, and 30 protons will impact the cockpit. THe rest mass of a proton is 900 MeV, we have 30, and they each have γ=7, so the ship will encounter an energy of 1.89(10^11) eV worth of energy.
Compare this to the energy of a dental X-ray. E=hf, f = 10^17, so the energy of a photon here is 65eV. In a typical dental X-ray, there would be 10^26 particles or so, so we have about 10^27 eV in a dental X-ray, and ~10^11 eV from outerspace protons.
Thus, a ship traveling with a γ = 7 will encounter much less energy from protons in deep space than it would by bombarding it with a dental X-ray. It is true that the deep space protons themselves are far more energetic than a dental X-ray photon, but there are so few, would it even be worth much worry? I would guess there are more relativistic protons from our own atmosphere via solar wind that pass through a human body per second than a ship traveling at light speed would have to worry about in deep space.
Does this calculation make sense? Why is shielding from outer-space protons appearing relatvistic in the ship's frame so much of a problem for near light speed travel? Or maybe its not so big a deal for β=0.99 but is more of a concern for higher β's.
Several major problems:
1) You don't compute dose over the whole journey. You compute a dose (even given all your figures) corresponding to the time it takes the ship to go one ship length. You need to mulitply this by, e.g. 100 light years / ship's length.
2) Your figures for the energy of an x-ray dose are way too high. See: http://en.wikipedia.org/wiki/X-ray
3) You ignore interstellar dust. You need to ask how much dust there is in ship's cross section X 100 light years. One speck could be devastating.
4) Your figures for overall density of interstellar medium are way off. See: http://en.wikipedia.org/wiki/Interstellar_medium. Note, you may encounter regions with 10^6 molecules per cubic centimeter.
5) You forget very rare events (that are not so rare over 100 light years). For example, a pinhead size piece of debris kicked into an interstellar region.
  • · Replies 18 ·
  • · Replies 52 ·
9K
  • · Replies 30 ·
  • · Replies 96 ·
13K
