Derivation of imaginary exponential function
The discussion centers on the derivation of the imaginary exponential function, specifically focusing on the expression exp(-ik1r) using Taylor expansion. The participants highlight that the Taylor series converges for low values of r (0.3 - 1.2) but fails to converge for larger values (100-1000). Key parameters include k0 = 21 and k1 = 27. A definitive approach to proving the relationship e^{\theta\cdot i}=cis(\theta) is suggested, emphasizing the use of Taylor expansion and differential equations for convergence analysis.
  • Understanding of Taylor series expansion
  • Familiarity with complex numbers and Euler's formula
  • Knowledge of convergence criteria for series
  • Basic differential equations
  • Study the convergence properties of Taylor series for complex functions
  • Learn about Euler's formula and its applications in complex analysis
  • Explore differential equations related to exponential functions
  • Investigate the behavior of series expansions for large variable values
Mathematicians, physicists, and students studying complex analysis or differential equations, particularly those interested in the properties of exponential functions and series convergence.
vinh pham
I would like to find derivations of exp(-ik0r) respect to k in order to calculate exp(-ik1r) by using Taylor expansion:
exp(-ik1r) = (exp(-ik0r))(0) +(k1 -k0)(exp(-ik0r))(1)/1! + (k1 -k0)2(exp(-ik0r))(2)/2! + ...
This expansion converges when the value of r is relative low (0.3 - 1.2). However, when r grows with larger value (100-1000), the expansion does not converge any more.
k0 = 21
k1 = 27
Is there any solution to find exp(ik1r) by using Taylor expansion for larger r?
Thank you very much
How do you know that for large r, it doesn't converge anymore? Early terms start to get larger, but how do you know that later ones also do?
Anyways, all you need for derivation of imaginary exponential function is proving that [tex]e^{\theta\cdot i}=cis\left(\theta\right)[/tex], none of these nasty k's, I think. Quite easily provable by substituting into the taylor expansion for exp, and similarly provable that it converges. I originally proved it, actually, with differential equations, noting that [tex]\dfrac{\exp'}{\exp}=\dfrac{cis'}{cis}=i[/tex] and proving that they differ by a constant, and plugging in 0 gives us the desired.
