Solve the Equation getting rid of square roots
  • Thread starter Thread starter Plutonium88
    Roots Square
The discussion revolves around solving the equation involving square roots: 1 + √((1+x)√(x^2-24)) = x. Participants are exploring the implications of squaring both sides and the resulting algebraic manipulations.
  • Mixed
  • Participants discuss various attempts to manipulate the equation, including squaring both sides and simplifying terms. There are questions regarding the correctness of the original equation and the algebraic steps taken. Some participants express confusion over the placement of parentheses and the implications for the equation's structure.
The discussion is ongoing with participants providing insights and corrections to each other's interpretations. Some have identified potential errors in the original setup, while others are exploring the implications of different algebraic approaches. There is recognition of multiple solutions, but no consensus on the complete resolution of the problem.
Participants note the importance of careful algebraic manipulation, particularly when squaring both sides of an equation, as it may introduce extraneous solutions. There is also mention of the need to factor rather than divide variables in certain steps.
Plutonium88
Solve the Equation... getting rid of square roots PLZ
1+ √((1+x)√(x^2-24)) = x
(x*√(x^2-24)) = (x-1)^2 (Square both side)
(-1)+1+(x^√(x^2-24) = (x^2 - 2x +1)-1
x^2(x^2-24) = (x^2 -2x)^2 (Square both sides)
x^4 -24x^2 = (x^2 - 2x)^2
x^4 -24x = x^4 - 4x^3 +4x^2
0 = -4x^3 +4x^2 +4x^2
0 = 4x^2 +4x+ 24
4x^2 -4x -24 = 0
What mistake am I making...
I honestly have tried a bunch of different times, and i had another student check it for me, and i can't catch the mistake I'm making!
edit:
I misread your equation, I think. Is it
[tex]1+\sqrt{(x+1)\sqrt{x^2-24}}=x[/tex]
RoshanBBQ said:
edit:
It is, he has the extra set of parentheses to imply this.
Edit: Now that I "solved" this (turns out to be a cubic equation) the answer isn't pretty and the equation might be something else that yields an easier answer).
The right hand side is fine (you subtracted the 1 and then squared) but the left hand side is incorrect.
Honestly i feel like a tool... I just rewrote the question on my board and did it... and this is the way i solved it earlier for my teacher..
unfortunately when i divided 28/4 i got... 6.. not 7.. i couldn't do simple math in my head... x.x
hers my solution i just took a picture off my whiteboard.. c.c
http://postimage.org/image/oku2wqccn/
I find... when i plug in 7 into the right side
1+all-sqrt(1+x)sqrt(x^2-24) = x
it resolves as 7...
therefore LS = RS Since X=7
Is This CorrecT?
Yes, 7 is the correct answer! You miswrote your equation in your first post which is why it confused us. You should have wrote:
1+ sqrt(1+x * sqrt[(x^2)-24]) = x
Or better yet:
[itex]\displaystyle 1 + \sqrt{1+x \cdot \sqrt{x^2-24}}=x[/itex]
You had parentheses aroung the 1 + x originally which implied their sum was being multiplied by the inside square root.
Or better yet:
Yea I'm silly like that.. Sorry, but thank you very much for your help, how do i write the equations like you guys are writing so they are much more visually evident.
You end it with[\tex]. You start it with [tex]. Then you use various commands that format into what we wrote. <br /> \sqrt{} is square root<br /> a^b is a power, but you can also do a^{b+c+d}. \frac{numerator}{denominator} is for fractions. I use this:<br /> <a href="http://en.wikipedia.org/wiki/Help:Displaying_a_formula" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://en.wikipedia.org/wiki/Help:Displaying_a_formula</a><br /> <br /> You can also always quote someone who has done it. You will then see how he created his equations in the quoted text. For example, try quoting me or scurty and seeing the [tex]statement.[/tex][/tex]
√Oh okay thanks a lot. Also I'm coming to find there are 2 solutions for this problem but I can't seen to find the other. I remember in trig there was a way to prove for ex.
Cosx + sinx = 0
Divide by cosx to get tanx
But because u got rid of cosx u could prove it wasn't part of solution anyway in lOst on finding the second solution...
at the point
1+√1+x√x^2-24 = x
√1+x√x^2-24 = x-1 (square both sdie)
1 +x√x^2-24 = (x-1)^2 (subtract 1 from both sides)
x√x^2-24 = x-2x
Divide by x here, and i believe this is where i determine the other solution, but how exactly?
√x^2-24 = X-2
Square both side
x^2-24 = (x-2)^2
x^2-24 = x^2-4x+4
4x = 28
x = 7
so yea this other solution :(
okay so another teacher helped me today at school with the solution.. My original solution is incorrect.
Variables cannot be divided by, you must factor them, or they can be removed by subtraction/addition.
so from this point.
x√x^2-24 = x^2 -2x +1 -1
x√x^2-24 - x^2 +2x = 0
x(√x^2-24 - x + 2)= 0
x = 0 or
√x^2-24 -x + 2 = 0
√x^2-24 = x -2
square both sides
x^2 - 24 = (x-2)^2
x^2 -24 = x^2 -4x +4
4x = 28
x = 7
Plug back in,1+√1+x√X^2-24 = x
X=7 is a solution
x= 0 not a solution due to extraneous roots.
  • · Replies 21 ·
