 Quote by Bill_K
OK, then how do you prepare a state that has a single photon?
The typical way relies on using some saturable transition like the elecronic states of a simple two level atom. If you excite it resonantly using a cw beam you will find that the two-level atom will show some emission into all directions. If you now have a look at the emission at right angle to your exciting laser beam (so you can distinguish between the emitted ligt and the light used for excitation) you will find that it consists of single photon states. The reason is simply that the atom returns to the ground state during an emission process and it takes some time to get it into the excited state again so that further emission events are ruled out for a brief period of time. In principle similar processes are possible for any fermionic two-level system. Unfortunately this is definitely not something for use at home.
One may also use single artificial atoms (like quantum dots) or defect centers in diamond. The latter are best for use at room temperature and the only realistic single photon source one might be able to use in an experiment at home. Nevertheless it will still be quite cumbersome to get it to work.
