New Reply
Euler’s method question
Share Thread Thread Tools
Apr3-12, 12:40 AM   #1
I need some help with the last part of the following problem:
3. The attempt at a solution
My approximation to the solution to the IVP at t=-0.8 using 1 step of the Euler's method was:
x(-0.8)=0.8
Whereas the approximation with 1 step of 4th order Runge-Kutta method was:
x(-0.8)=0.8214
And since the exact solution is
[itex]x(-0.8) = e^{-0.8 +1} -2 \times (-0.8) -2 = 0.8214027582[/itex]
the error in Euler's method would be
[itex]|0.8214027582-0.8| =0.0214027582[/itex]
And the error for Runge-Kutta is
[itex]|0.8214027582-0.8214| =2.7582 \times 10^{-6}[/itex]
I'm stuck here. So how many steps does Euler's method take to produce an answer with an error no larger than 2.7582 x 10-6 (the error of Runge-Kutta)?
I tried to use the following equation:
[itex]e_n \leq \frac{k}{n}[/itex]
Where k is a constant and n is the number of steps and en is the error. I then tried to solve for the constant bu substituting in the values from Euler's method:
[itex]0.021402758 = \frac{k}{1} \ \implies k =0.021402758[/itex]
Then substituting in the new error
[itex]2.7582 \times 10^{-6}=\frac{0.021402758}{n} \ \implies n = 7760[/itex]
But doesn't 7760 steps seem too much? Where did I go wrong? I appreciate it if anyone could help me with this problem.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr3-12, 01:24 AM   #2
Recognitions:
Homework Helper Homework Help
7760 seems to be OK. You could confirm this using a program or a spreadsheet with Δt = (0.2 / 7760) to see if it corresponds with your answer.
Apr3-12, 05:07 AM   #3
But I am wondering if I've even used the correct method for finding the number of steps?
Apr3-12, 09:01 AM   #4
Recognitions:
Quote by roam View Post
What was the source of the error equation you used, class notes, a textbook, ... ?
Apr3-12, 04:06 PM   #5
Quote by rcgldr View Post
It's from a textbook...
Edit: page 635 of the textbook called "Differential Equations" by Blanchard, Devany and Hall.
Apr3-12, 05:25 PM   #6
Recognitions:
It appears that you have. As mentioned before if you want to check this, you could confirm this using a program or a spreadsheet using Euler method with Δt = (0.2 / 7760) to see if it corresponds with your answer (for the spread sheet you would need to use 7761 rows, the initial state and 7760 steps).
New Reply
Thread Tools
Similar Threads for: Euler’s method question
Thread Forum Replies
Integrating Euler's equations for rigid body dynamics with Euler's Method Differential Equations 0
Question on Euler's method - ODE Calculus & Beyond Homework 1
Euler methond and the improved Euler method Differential Equations 4
Euler's method question Calculus & Beyond Homework 2
Euler's Method question. Differential Equations 4
