Question about open sets in (-infinite,5]
  • Context: Graduate
  • Thread starter Thread starter dodo
    Sets
The discussion revolves around the concept of open sets within the context of the metric space defined by the interval (-∞, 5]. Participants explore whether the interval (4, 5] can be considered an open set in this space, particularly under different metrics, including the Euclidean metric.
  • One participant questions whether (4, 5] is an open set in the metric space (S, d), suggesting that the open ball B(5, 1) corresponds to (4, 5] under certain conditions.
  • Another participant asserts that (4, 5] is open, but acknowledges that the answer depends on the specific metric defined on S.
  • A third participant emphasizes that without a defined metric, it is impossible to determine the openness of (4, 5]. They suggest that the question should refer to the restriction of the Euclidean metric to the set S.
  • One participant introduces the concept of quotient topology, arguing that (4, 5] is the intersection of an open set in R and S, and discusses the implications of using the definition of a metric.
  • Another participant clarifies that while (4, 5] may be open under some metrics, it is not necessarily so under all metrics, highlighting the variability of metrics on R.
  • A later reply acknowledges the confusion in the original question and clarifies that their doubt was specifically about open balls with the Euclidean metric.
Participants express differing views on whether (4, 5] is open, with some asserting it is open under certain metrics while others argue that it is not necessarily open without a specified metric. The discussion remains unresolved regarding the generality of the claim.
Participants note that the lack of a specific metric complicates the determination of openness for the interval (4, 5]. The discussion also touches on the implications of the quotient topology and the intersection of open sets.
dodo
The stupid question of the day.
If S is the real interval (-infinite, 5], and I can find a metric d so that (S,d) is a metric space, then,
is, for example, (4, 5] an open set in (S,d) ?
I say this because, the way I'm reading the definition of an open ball, the open ball B(5,1) is the interval (4,5] and not the interval (4,6), since the points in (5,6) do not belong to the metric space (S,d). So every open ball in (4,5] centered in 5 is completely contained in (4,5].
Yes, (4,5] is open.
Thanks, micromass, just checking the fundamentals.
By the way, I apologize for the phrasing of the question; if the metric d is not specifically defined, then there is really no way to tell. As someone else pointed me out, the question should have referred to the restriction of the Euclidean metric to the set S.
In that case you automatically have to deal with the quotient topology on S and obviously (4,5] is certainly the intersection of an open set of R and S. Of course just using the definition of metric also works. All points with distance smaller then 1 are in B(5,1) but, this means of course all point that are in your space. Otherwise it wouldn't make much sence.
micromass said:
Yes, (4,5] is open.
Not necessarily. The question posed by the OP is if he can find a metric turning [itex](-\infty, 5][/itex] into a metric space, then is (4,5] necessarily open. This is the question as it's posed, and the answer is not necessarily. He did not specify what the metric would be, so there's no guarantee that the metric would in any way resemble the regular Euclidean metric. There are many metrics that one can construct on [itex]\mathbb{R}[/itex], and then a restriction to his subspace S yields a metric on S. In some of those metrics, (4,5] may be open. In others, they may not.
If the question were specifically about the regular Euclidean metric, then the answer is yes.
... read third post
Thanks all for your answers! My actual doubt was about open balls with the Euclidean metric, but I did a awful job formulating it -- it's clear now.
The quotient topology, as far as I learned, deals with an equivalent relation on the space and is defined on the space of equivalent classes of the original space. This case is just a subspace defined by the intersection of the open sets with the subset. Correct me if I'm wrong.
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 0 ·
