Finding real part of complex eqn
  • Thread starter Thread starter charmedbeauty
    Complex
The discussion revolves around finding the real part of a complex expression involving the variables z and w, where z is given in exponential form and w is a complex number. Participants are analyzing the expression Re(iw + \overline{z}^{2}) and exploring the implications of squaring complex numbers and converting between forms.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the conversion of z from exponential to rectangular form and the implications of squaring complex numbers. There are questions about the correctness of the calculated values and the interpretation of angles in the Argand diagram.
There is an ongoing exploration of the calculations involved in finding the real part of the expression. Some participants have offered guidance on how to approach the squaring of complex numbers and converting between forms, while others express confusion about the process and seek clarification.
Participants mention constraints such as the need to stay within the interval [-π, π] for angles and the challenge of finding relevant examples in their textbooks. There is also a reference to the use of Euler's formula in the discussion.
charmedbeauty
for z= 3e[itex]^{(-5\pi i/6)}[/itex] and w=1+i
find Re(iw+[itex]\overline{z}[/itex][itex]^{2}[/itex])
[itex]\overline{z}[/itex]= 3e[itex]^{5\pi i/6}[/itex]
so |z|=3 and Arg(z)= 5[itex]\pi[/itex][itex]/6[/itex] which lies in the second quad. so we have z= -1+ i[itex]\sqrt{3}[/itex]
so squaring z I have 1-2i[itex]\sqrt{3}[/itex] -3
so Re(z) = -2.
and for the w once I times through by i we have w=i-1
so I thought it should be something like Re(iw+[itex]\overline{z}[/itex][itex]^{2}[/itex])=
-1+-2=-3
But the answer says 7/2
Im sure I have gone wrong somewhere please help!
That's impossible. That has absolute value [itex]\sqrt{1+ 3}= 2, not 3.. [itex]cos(5\pi/6)= -\sqrt{3}/2[/itex] so [itex]3cos(5/pi/6)= -3\sqrt{3}/2[/itex], not -1. [itex]sin(5/p/6)= 1/2[/itex] so [itex]3sin(5/pi/6)= 3/2[/itex], not[/itex]\sqrt{3}[/itex].
[itex]\overline{z}[/itex] (not z) is equal to [itex]-3\sqrt{3}/2+ (3/2)i[/itex]
so Re(z) = -2.
-1+-2=-3
so Re(z) = -2.
-1+-2=-3
So you want the real part of [itex]i + i^2 + (3 e^{\,i 5 \pi/ 6})^2.[/itex]
RGV
RGV
Yes which the first part is equal to i-1 its just the second part I am confused with.
So, are you saying that you don't know how to calculate [itex](r e^{i \theta})^2[/itex] for real [itex]r \text{ and } \theta?[/itex] Have you tried looking in your textbook, or looking on-line?
RGV
RGV
Yes but I can't find any similar examples on line and I only have a calculus textbook.
But I think I am confused about what happens when I square the term.
Should I convert it to a+ib form and then square it or just square it in exponent form because If I do that I get e^10Pi*i/6 once I have squared and changed it into its conjugate form.
But that means I have an angle of 300 deg. Which I got stuck on because I did not know what quad it should be in on the argand diagram since it only uses the interval [-pi,pi], so where does 300 deg fit in there? do you got to 180 then go back in the opp direction or do you keep going around to the 4th quad but then that should give a negative 'a' and negative 'bi' ?? I am really confused on this.
Google is your friend. See, eg., http://en.wikipedia.org/wiki/Complex_number and look about 2/5 of the way down. Frankly, I am very surprised that you have not seen this material before, since it is so very fundamental.
RGV
RGV
OK so basically if its out of the range of [-pi,pi] just add 2kpi to make it in the right interval?
[itex]\overline{z}[/itex][itex]^{2}[/itex] = 9([itex]{{\rm e}^{5/6\,i\pi }}[/itex])^2
So you essentially get 9(cos([itex]\frac{5\pi}{6}[/itex])+isin([itex]\frac{5\pi}{6}[/itex]))^2
Once you simplify that trigonometric expression, you should be able to calculate the real part of that fairly easily, once you have that, you simply add on the real part of (i*w)
Remember Euler's formula:
http://en.wikipedia.org/wiki/Euler's_formula
Yes, as you got (10*Pi)/6 - simplify that, and get it into range by adding or subtracting 2kPi
Since you did the squaring directly in the exponential, this will save you some work when you convert it into trig form, then it's pretty much solved.
Ok Thanks!
  • · Replies 17 ·
