Determining background radiation in a decay spectrum
The discussion focuses on calibrating software for analyzing decay spectra and addressing the impact of background radiation on the results. The user seeks guidance on how to effectively measure and subtract background radiation from spectra generated by a detector without a radioactive source. It is established that running the detector without a source for an impractical duration is not necessary, and environmental factors, such as shielding, can influence the detection of nuclear gammas like Cs137.
  • Understanding of decay spectrum analysis
  • Familiarity with background radiation measurement techniques
  • Knowledge of Compton scattering and backscatter peaks
  • Experience with software calibration for radiation detectors
  • Research methods for background radiation subtraction in decay spectrum analysis
  • Learn about the effects of environmental shielding on gamma detection
  • Explore software tools for calibrating radiation detection systems
  • Investigate alternative techniques for measuring background radiation efficiently
Researchers in nuclear physics, radiation safety professionals, and laboratory technicians involved in decay spectrum analysis and calibration of radiation detection equipment.
physguy09
I was working on calibrating some newly purchased software onto our lab computers when I noticed that the decay spectrum on the screen did not look exactly as it does on published material. I attribute this to background radiation effects (correct me if I am wrong please), so I decided the best way to test the background rate would be to run the detector being used without a radioactive source.
My question: how do I then use this data to remove it from generated spectra? I initially thought I would run the detector without the source for the same amount of time as I had with the source, but this would mean running it for days at a time in cases of weaker sources...seams rather impractical. May someone point me in the right direction please?
If you are looking at nuclear gammas (e.g., Cs137), the local environment (e.g., shielding) can affect the amplitude of the Compton edge and backscatter peaks.
12K
  • · Replies 29 ·
  • · Replies 19 ·
  • · Replies 26 ·
