Why 8 Gluons? Explaining the Mysterious Dual Charge of Gluons
  • Context: Graduate
  • Thread starter Thread starter Kalimaa23
    Gluons
The discussion revolves around the nature of gluons and their dual charge, specifically addressing why there are 8 distinct gluons instead of 9, as suggested by the color charge combinations. Participants explore theoretical aspects of quantum chromodynamics (QCD) and group theory, including the implications of SU(3) and U(3) symmetries.
  • One participant questions the reasoning behind subtracting one colorless combination from the 9 possible gluon combinations, suggesting that there are three colorless combinations instead.
  • Another participant clarifies that the colorless combination refers to a singlet state, which is unique and does not contribute to the count of independent gluons.
  • Some participants discuss the mathematical structure of SU(3) having 8 generators and U(3) having 9, questioning the significance of this distinction.
  • There is a mention of algebraic relations in SU(3) that reduce the degrees of freedom, leading to only 8 independent generators being necessary to describe the symmetry.
  • One participant elaborates on the physical interpretation of color singlets and their inability to interact due to lack of color change, contrasting this with non-singlet states that can interact.
  • Another participant corrects a previous claim about the properties of SU(N) matrices, emphasizing the need for tracelessness in the generators rather than the matrices themselves.
  • There are expressions of uncertainty and confusion regarding the definitions and implications of color charge and symmetry groups, particularly in relation to introductory knowledge of QCD.
Participants express differing views on the number of colorless combinations and the implications of group theory in the context of gluons. The discussion remains unresolved regarding the exact reasoning for the count of gluons and the properties of SU(3) matrices.
Some participants acknowledge limitations in their understanding of the mathematical formalism and physical interpretations involved, indicating that the discussion is rooted in complex theoretical concepts that may not be fully resolved.
This discussion may be of interest to students and enthusiasts of quantum field theory, particularly those exploring the fundamentals of quantum chromodynamics and group theory.
Kalimaa23
Greetings,
I found a puzzling reference in my EP-course, that basically says :
"Gluon cary a dual charge, one colour and one anticolour. This means one can have 3²=9 combinations."
So far, so good. But then :
"We have to substract one colourless combination. This leaves us with 8 gluons."
Huh? Why one colourless combination? I can see three :
Blue/Antiblue
Green/Antigreen
Red/Antired
Which would leave us with 6 gluons, which is obviouly wrong. Can anyone explain this to me?
Thanks in advance,
Dimi
'Colorless' means color singlet in this context, of which there is only one type:
[tex]\Psi_c =\frac{1}{\sqrt{3}} (r\bar{r}+b\bar{b}+g\bar{g})[/tex]
Technically, SU(3) has 8 generators, while U(3) has 9. Why SU() instead of U()?
My prior knowledge of this matter is rather limited.
I see what the colourless combination looks like. What about the others? What do they look like?
I haven't got the slightest idea. Something to do with inversion symmetry? Parity? :confused:
Dimitri Terryn said:
Greetings,
Blue/Antiblue
Green/Antigreen
Red/Antired
Thanks in advance,
Dimi
Roughly, there would be nine, but there are algebraic relations since the matrices of SU(3) are unitary. This knocks out one degree of freedom. The situation is that if you know any eight, you can solve for the ninth, so there are really only eight independent generators.
Well, this is quite vague. What is meant here is that indeed you only need eight generators in order to describe the entire symmetry group (local SU(3)-colour-symmetry). These generators really are the conserved quantity at hand, which is in this case colour. Basically this means that when particles with colour interact (like gluons and quarks and...) the total net-colour needs to be conserved (this works just like energy conservation).
A coloursinglet is a state describing a particle of which the "colour-part" cannot change when you perform colour-tranformations on it (think of these colourtransformations as rotations and they are the actual inhabitants of the SU(3)-colour-world). A particle that is a singulet is observable. So quarks on themselves are NOT observable for this reason : they carry an overall colour (R,G or B). Now watch it: a red-antired quark may seem white but it is NO coloursingulet. And being really or truly white means being a coloursinglet.
In grouptheory, you can prove that if a local symmetrygroup has dimension N, there will always be N²-1 generators that generate the transformations under which the physical quantities (like a lagrangian) need to be invariant...
But this is all math. A more physical interpretation is this one : If the wavefunction of some gluon is completely white, then there is no colour and no interaction can go on. Basically this state is a singulet which means that it can never change (no change in charge, and so on...). Now for a gluonstate to be white there is ONE condition: the particle cannot have any preference for any colour. This means that the gluon must be red-antired, green-antigreen, AND blue-antiblue.
Now incorporating some normalization-constants we have that : the
white gluon is (red-antired + blue-antiblue + green-antigreen)/sqrt(3).
For example there are two kinds of wavefunctions that are not actually white: (red-antired -green-antigreen)/sqrt(6)
and (red-antired + green-antigreen -2*blue-antiblue)/sqrt(6).
These two gluons can interact without changing
the color of a quark, but they are not completely white.Indeed, colourcharges interact via the exchange of colour. So the singlet state cannot interact because it cannot change its colours. that's why it is a singlet !Now, a red-antired gluon is indeed white BUT NO SINGLET because the colour can be changed. Indeed the total colour is white but so is the total colour of a blue-antiblue gluon so it can change into that for example. You see the difference between being white and being TRULY white ?That is the main point
An analogous things happens in the quantum information theory. Suppose you have a wavefunction that is a superposition of spin up and down. Suppose that the probability for measuring the spins along some axis is 1/2 then you really know nothing at all do you ?This same thing happens with the TRULY white wavefunction. For this reason all combinations that yield white must be included
Check out my journal for more info...
regards
marlon
ps : veel succes met de QFT-studie Dimitri...geniet ervan... :wink:
BTW this is a very good question Dimitri...
regards
marlon
Because SU(3) is a local symmetry-group and U(3) is global. the rule is that the number of generators of a local group of dimension N is N²-1. Besides the -1 comes from the fact that SU(N)-matrices are unitary and traceless
regards
marlon
marlon said:
Besides the -1 comes from the fact that SU(N)-matrices are unitary and traceless.
regards
marlon
WHAT??
Jesus,Marlon,it's your area of expertise.QCD,remember??Group theory,remember?How can u say that?
SU(N) matrices are unitary and have determinant "+1".Generators of the matrices which form the Cartan subalgebra (of the Lie algebra su(n) of the group SU(N)) are traceless,not the matrices form SU(N).
That's a shocker,Marlon... :rolleyes: Didn't expect that...And u're saying all things about me... :wink: :rolleyes:
Daniel.
PS.U've written that thing at almost 2 a.m.Yet fatigue it's not an excuse.Not in this case...
Hi DIMITRI, oe ist ?
Hi Dimitri, I indeed made a mistake in stating that SU(N) matrices are traceless. Of course they are NOT...Sorry for that...
Any unitary matrix U can be written as U =exp(iH) where H is a matrix with the property that [tex]H^{+} = H[/tex]
Given the fact that det(U) = exp(iTr(H)) where Tr denotes the trace, we can conclude that all generators of SU(N) are hermitic and traceless N*N-matrices. Because of hermiticity you have N² matrices and the need to be traceless gives an extra condition so in toto you have N²-1 matrices that obey these two conditins at the same time. Thus N²-1 generators for SU(N)...
That is the complete picture...
ps : let niet op de onvolledige verklaring van dextercioby, de laatste dagen doet die niets anders als mij willen verbeteren... :rolleyes:
regards
marlon
Thanks a lot Marlon. Mind you, this is only an introductory course. Next semester I'll have a decent QED course... Then I'll be around with more questions :-p
And we shall be ready to help you out at any given time on any given place... :cool:
marlon
marlon said:
snip...
Just a comment: it's not a question of local vs gauge symmetry whether the number of generator is N^2-1. It's just a question of which group is involved. SU(N) has N^2-1 generators, U(N) has N^2 generators. This is the math part.
Now, which of this group is a local (gauge) symmetry group is a matter of experimental verification, not of mathematics. It turns out QCD is SU(3), but
Nature could have chosen U(3) (in which case the world would be quite different!)
Patrick
I agree...
Patrick
Depends on how you look at it. I do see your point and i agree. However, just look at how the eightfoldway was born. Basically the SU(3) representation was born because via tensor-products of this fundamental representation we could construct the mathematical formalism (using baryons and mesons) that would correspond to the results of the eightfolds...
Just a some way to look at it and this is what i intended.
regards
marlon
  • · Replies 27 ·
9K
  • · Replies 21 ·
