| New Reply |
Resistor & Ideal source network |
Share Thread | Thread Tools |
| Apr14-12, 02:01 PM | #1 |
![]() 2. Relevant equations General intuition, KCL, KVL 3. The attempt at a solution I've worked this out multiple ways to no avail. I think the easiest way to go about this is to set the left node to ground (0 potential) and go from there. EDIT: Using the assumption that my first statement below is correct, I found the solution of -46V. My second question still holds though. Here are a few things that none of my professors or TAs have been clear on: 1) When you have current through a resistor (such as Io), using Ohm's law you then know the voltage. Something I'm very unclear on is which way the voltage drops across the resistor. In my class, we use current from positive -> negative as dissipated power with a positive sign (like in a resistor), and negative to positive as a source, with a negative sign. Does this mean that the potential at the bottom node is -2V? 2) How can you have a potential across an ideal current source when the component doesn't have a resistance? |
| Apr14-12, 03:30 PM | #2 |
2.) An ideal current source has infinite resistance The idea is no matter what voltage is applied to the current source, you want a certain current to flow. Think about it this way: P = IV. If you have a current source, it is forcing current to be a certain value. Given the circuit, to do this enforcement, it may have to add power or subtract power. E.g. if it is a simple current source resistor combo, you obviously add power. But in other circuits, it may be that without the current source, you would have more current flowing through that branch, meaning the current source sucks power away to enforce the smaller current. So we can agree a current source contributes power. Well, if P = IV, we know there has to be an I through it and a V across it. Otherwise, no power is contributed. |
| Apr14-12, 03:47 PM | #3 |
One more question regarding potential across a current source: There was another question where I needed to make a circuit so there was 0 potential across a current source so it wouldn't contribute to the overall power. Even with a 0 potential across the source, isn't the 3A still flowing since that's the very definition of an ideal source? How can you have current that doesn't contribute to the power of a system? |
| Apr14-12, 05:03 PM | #4 |
Resistor & Ideal source networkFor your second question, consider a 1V voltage source hooked up in series with a 1 ohm resistor hooked up in series with a 1 A current source. In this situation, the voltage source is already delivering the 1A, so it delivers all the power. The current source is sitting there doing nothing. It wants there to be 1 A and there already is. It brings in or sucks out zero power. The voltage drop across it will be 0V to reflect this lack of power delivery or consumption. |
| Apr14-12, 05:13 PM | #5 |
| Apr14-12, 06:11 PM | #6 |
| Apr14-12, 06:21 PM | #7 |
| Jul29-12, 05:49 AM | #8 |
what is the step function and impulse function of capacitor and inductor? please reply.....it s really urgent
| New Reply |
| Tags |
| current source |
| Thread Tools | |
Similar Threads for: Resistor & Ideal source network
| Reducing resistor network | Electrical Engineering | 4 | ||
| Resistor Network troubles. | Introductory Physics Homework | 3 | ||
| resistor network | Introductory Physics Homework | 4 | ||
| Resistor Network | Introductory Physics Homework | 2 | ||
| resistor network | Engineering, Comp Sci, & Technology Homework | 4 | ||
