Is Cold Plasma a Reality in Physics?
  • Context: Undergrad
  • Thread starter Thread starter taeth
    Cold Plasma
The discussion revolves around the concept of "cold plasma" in physics, exploring its existence, characteristics, and the conditions under which it can be formed. Participants examine the definitions of plasma, its states, and its applications in various contexts, including astrophysics and technology.
  • Some participants question how "cold plasma" can exist if plasma is typically considered the most energetic state of matter.
  • Others mention that plasma can exist at various temperatures, with examples like the plasma found in fluorescent bulbs being relatively cold.
  • A participant references research on ultracold plasma created through photoionization of laser-cooled atoms, highlighting specific temperature ranges and behaviors.
  • Some argue that plasma does not necessarily have to be hot, as it can be defined as a gas that is electrically charged or ionized, regardless of temperature.
  • There is a discussion about the different contexts in which the term "plasma" is used, including biological plasma and its historical naming origins.
  • Participants explore the idea that even room-temperature electrons in metals could be considered a form of plasma.
  • Some contributions clarify that the term "plasma" encompasses a variety of states and definitions, including ionized gases and electron fluxes in electric discharges.
  • One participant raises a question about the conditions under which any substance might enter a "plasmatic" state when heated sufficiently.
Participants express a range of views on the nature and definitions of plasma, with no consensus reached on the implications of "cold plasma" or the specific conditions required for its existence. The discussion remains unresolved regarding the broader definitions and contexts of plasma.
Participants note that definitions of plasma can vary significantly based on context, and there are unresolved questions about the specific conditions that qualify a gas as plasma. The discussion also highlights the complexity of distinguishing between different types of plasma and their behaviors.
taeth
I thought plasma was the most energetic state of matter, and that heat is proportional to energy levels? How is it possible for cold plasma then?
Can you put the question into some context? Where did you hear the term "cold plasma" being used? I've been following the lively doings over at the Princeton Plasma Physics Lab, where they are trying to intiate fusion by compressing (and therefore heating) plasma. To achieve ignition, they need something like 15 million degrees, so for them a plasma that is 1 million degrees is far too cold, practically freezing!
I am not sure Iwas just reading somewhere that cold plasma exists in the sun where it is virtually not even hot enough to burn you, yet it is still excited enough that it can erradicate bacteria, and create protection from radiation(because plasma tends to have a such a strong electromagnetic field)
A plasma is just positively ionized gas (by "positively", I mean that electrons are stripped off from the atoms, and not added to them, so the ionized atoms are positively charged). I'm quite sure there are ways to ionize a gas without heating it (shining a laser with the proper wavelength on it should do the trick I beleive), although keeping it ionized may be a problem below some threshold temperature.
Yes, and in some contexts you can model the vacuum of space or the ionosphere as a plasma, with a quantity N electrons per m^3.
Ultracold plasma by ionization of ultracold atoms
See this article:
Phys. Rev. Lett. 83, 4776–4779 (1999)
Creation of an Ultracold Neutral Plasma
T. C. Killian, S. Kulin, S. D. Bergeson*, L. A. Orozco§, C. Orzel, and S. L. Rolston
National Institute of Standards and Technology, Gaithersburg, Maryland
We report the creation of an ultracold neutral plasma by photoionization of laser-cooled xenon atoms. The charge carrier density is as high as 2 x 109 cm-3, and the temperatures of electrons and ions are as low as 100 mK and 10 µK, respectively. Plasma behavior is evident in the trapping of electrons by the positive ion cloud when the Debye screening length becomes smaller than the size of the sample. We produce plasmas with parameters such that both electrons and ions are strongly coupled.
-Beth
Yeah plasma is just gas with it's electrons stripped off. The plasma in florecent bulbs is cold by plasma standards.
Isn't plasma matter at a highly energetic state, the next step up from gas?
It is any gas that is electrically charged or, like solar plasmas, has had it's electron's stripped off, leaving it's nulcei bare. So techniquely it does not have to be energetic (hot) to be a plasma.
By themselves, the free electrons inside a room-temperature metal can be said to constitute a plasma. A (-) plasma enclosed in a (+) charged crystal.
As I recall, any highly ionized gas can be called a plasma, and what's that stuff in plasma tvs?
I believe that you could make ionized gas simply by sticking a needle on the top of a positively-charged Van de Graff generator. Would this be considered plasma, or is it too diluted?
It's real plasma in the screen, real as in electrically charged gas. Plasma may seem like an exotic material, but it's really quite common.
I just thought of something. What's blood plasma? Why do they call it a 'plasma'?
Blood plasma is basically the mixture of liquids in the blood in which the cells are suspended. It's composed mostly of water and a bunch of organic compounds.
According to http://www.plasmacoalition.org/what.htm, blood plasma came first, and physics plasma was named after it. It also says, though, that the connection is unclear.
The term "Plasma" must have roots in a word that means something like "fuzzy medium". So Biologists used the term to coin the "fuzzy medium" that carries cells etc. while Physicists used the term to coin the "fuzzy medium" between highly polarized electrodes.
It seems we have three uses of the word "Plasma" here. The biological plasma is quite different from the other two, and is simply a water-based liquid carrying various dissolved minerals and suspended organic solids used as a support and transport mechanism for living cells.
A Plasma gas such as is found in the ionosphere is one that is highly charged due to removal of electrons from the atoms in the gas.
The word Plasma may also be used to describe a more fundamental grouping of particles, such as the electron flux in a spark discarge, whethor from a Van de Graff generator or from any other generator, battery, etc. This type of plasma involves only electrons (or other fundamental particles) and is not made up of atoms at all.
Plasma then in general refers to a gas or liquid which carries charged particles. Specifically, the charges may be carried on ions, disolved in a liquid such as blood plasma, or the charges on atoms, in an electron deprived ionic gas in the upper atmosphere, or in the liquid-like flux of the bare charges themselves, in a spark or other beam of energetic fundamental particles.
In this last definition, many of the behaviors of electrons in conducters like ordinary copper wire can be thought of as if the electrons (on the surface anyway) are to some degree ionized, or free of the atoms which support them. The flux or current in the wire can be thought of as if the surface electrons were free to flow along the wire like a liquid or a gas might flow through a pipe. Even though these electrons behave in many ways like a liquid or a gas, and so fit the definition of a plasma, the wire which carries them is still quite solid to the touch and can be cool or even cold.
nc
As far as I know, the plasma of an electric discharge is the same that of an ionized gas. When the electrons go through, they eject electrons from the gas. You would not see anything if the electrons were alone. The glow you see from a van der Graaf is the same as aurora borealis or lightning, or a static discharge spark, all ionized gas.
Nice reasoning, but I would need a reference to be convinced that biological plasma specifically refers to the electric charges.
Definition of Plasma
Loosely, and from Jackson's "Classical Electrodynamics,"
An ionized gas should be called a plasma when the length scale which separates short range and long range behavior is short compared to the length scale of interest. Not all ionized gases are plasmas. For example, a very dilute gas of a few moving charged particles, interacting pairwise, is not a plasma. The conduction electrons in a metal are not a plasma, either. It is not always easy to tell if something is a plasma, really. Crudely, if you have to consider the inertial effects of the positive and negative charge carriers in the dynamics (say, in response to an applied electric field), then you've got a plasma.
"Plasma" is also the name of a certain variety of green quartz. Why, you may ask? I haven't a clue. How do I know this, you might inquire? I had lots of free time in my childhood.
Oh, by the way, I was wondering: If any substance gets heated enough, will it enter an, um, "plasmatic" state?
