Max amps in a wire? Any charts or
The discussion revolves around the maximum current that can safely flow through a wire, exploring factors such as wire gauge, voltage, resistance, and thermal considerations. Participants share formulas, practical methods for measurement, and reference charts related to wire specifications.
  • Some participants assert that the maximum current depends on the wire gauge, with larger diameters resulting in lower resistance and higher current capacity per unit voltage.
  • Others emphasize that the current capacity is also influenced by the voltage across the wire and the resistance of the wire's length.
  • A formula is presented for calculating current through a wire as current = voltage / resistance of wire per unit length, though some participants challenge its applicability in practical scenarios.
  • Concerns are raised about the thermal effects of current flow, with a focus on how heat generation relates to resistance and current, and the importance of maintaining safe operating temperatures to prevent insulation damage.
  • Some participants suggest using charts from electrical manufacturers to determine resistance per unit length and safe current limits, while others caution that these charts may be conservative.
  • There is a discussion about the use of circular mils as a safety factor for determining current capacity, with varying recommendations on the number of circular mils per amp.
  • A participant questions the accuracy of using an ohm meter for measuring resistance in practical applications, suggesting that it may not provide reliable data for current capacity calculations.
  • One participant mentions the National Electrical Code's charts for maximum amperage based on wire gauge and ambient temperatures, indicating a reliance on established standards.
Participants express differing views on the applicability of formulas for calculating current, the reliability of resistance measurements, and the interpretation of charts for wire specifications. No consensus is reached on the best approach to determine maximum current capacity.
Limitations include potential inaccuracies in resistance measurements, the dependence of calculations on specific conditions such as ambient temperature, and the varying interpretations of safety factors in wire usage.
This discussion may be useful for electricians, engineers, and anyone interested in electrical wiring, safety standards, and the practical applications of electrical theory.
infamous_Q
anything out there that could help me with this? or is there no limit? or does it depend on gauge?
Yes, it depends on gauge. Did you try google?
it does depend on the gauge indirectly
but directly it depends on the voltage across the wire and the resistance of the wire's length
the bigger the diameter(gauge) the less the resistance of the wire per unit length and this yeilds more current per unit voltage
the formula for finding out how much current is through a wire is
to find out the resistance of wire per unit length
use an ohm meter to measure a length's ends
Another way to find out the resistance of a wire per unit length of a particular wire diameter (gauge) is to get some charts showing resistance per unit length of wire qauge and multiply or divide that to your choosing length
you can get such charts at electrical/wire manufacturers/retailers
That's a poor application of ohm's law. Typically the wire is used to deliver power to a load and is not the load itself so therefore the exclusion of the load makes this calculation worthless.
A method to determine how much current a wire can safely handle is a matter of temperature control. Even a small wire can pass large amounts of current for brief periods of time but will heat up while doing so. To find the amount of heat, find the resistance and current and use the following:
resistance*current^2 = power loss on wire in watts = heat
Now the thermal mass of the wire (how long it takes x watts to reach y temperature) and the safe level for the insulation and the ability of the wire to dissapate the heat to reach a state of equilibrium are other factors.
The cross-sectional area of the wire is like a pipe or hose for delivering water - a firehose can deliver much more water than a garden hose at the same pressure. Its called circular mils.
As a safety factor, the amount of current allowed to flow over a certain number of circular mils is used and is conservative. If the wire were in a bundle of other wires and not able to dissapate the heat, we wouldn't want it to build up enough heat to melt the insulation and cause a short. So some charts use 300 circular mils per amp, and some use 200 circular mils per amp. Using only 200 nets a higher number because it allows more current per unit of cross sectional area but reduces the safety factor.
Unless you have a lab grade low resistance meter this is highly inaccurate and the resistance is tyipcally well within the tolerance of the meter in cases where current flow is of concern. And it doesn't matter anyways, see above for the reason why.
Another consideration is the power delivered to the load and losses in the transmission. The heat calc above shows how many watts are lost just in the wire. This means less power is available to the intended load because the series resistance of the wire (like a series resistor) drops some voltage and thus reduces the available power.
Most charts you will find online are conservative enough where this isn't much of a concern but you should be aware of the variables.
Cliff
Oh, and here's a link if all you wanted was a quick answer. This author spends more time on the explanation of terms further down the page and uses 300 mils/amp in his second chart from the top in recommending fuse sizes.
http://www.bcae1.com/wire.htm
Cliff
Also check out the American Wire Gauge tables, or one of the millions of links to their tables online.
Hey, nothing personal is meant here - this is about answering someone's question with useful and accurate information.
I can follow your post I quoted above, I'll take my Fluke 87 and measure a wire and it shows .03 ohms. I've got a 12 volt battery in my car, and using your equation I get 400 amps. So my wire can take 400 amps then? For how many microseconds?
Using circular mils to determine current capacity or referencing charts that have already factored this into account is far safer than understanding the basics of ohm's law and applying them out of context and in a way that could lead to fires!
Averagesupernova, this is your cue to add the last word. :smile:
:approve: Since I agree with you Cliff, I'll let you have it.
Whoa! lot more response than i expected. Thanks everyone!
oh. one more thing, how would i find the thermal mass?
philo, do you understand why your suggestion doesn't work ? There's no harm in learning !
Umm, I'm an electrician and i can tell you that the national electrical code has a chart of american wire gauge sizes and their max amperage (ampacity), although it is probably a bit on the conservative side. also these figures are based on (given) ambient temps.
  • · Replies 28 ·
18K
