Kinematics: Understanding Acceleration and Deceleration - Questions 7 and 11
  • Thread starter Thread starter Imanroc8
    Kinematics
The discussion revolves around kinematics, specifically focusing on acceleration and deceleration in the context of two questions related to motion equations. The original poster seeks assistance with deriving equations and understanding conditions for their validity.
  • Participants explore the relationship between acceleration, initial velocity, final velocity, and time. There are attempts to rearrange equations and apply them to specific problems. Questions arise regarding the conditions necessary for the equations to hold true and the implications of negative values in calculations.
Some participants have provided guidance on rearranging equations and highlighted the importance of consistent values for acceleration. There is acknowledgment of mistakes made in calculations, and a few participants express clarity on the problems after receiving assistance.
Participants note confusion regarding the conditions for the validity of motion equations and the implications of using different values for acceleration in their calculations. There is also mention of homework constraints that may limit the exploration of concepts.
Imanroc8
Question 7
a) Acceleration is the rate of change of velocity
Use your definition in (a) to show that v = u + at, where v is the final velocity, u is the initial velocity and a and t are the acceleration and the time interval respectively.
State the conditions that must be satisfied for the equation to be valid.
Question 11
An aircraft has a landing velocity of 50m/s and decelerates uniformly at 10m/s^2 until its velocity is reduced to 10m/s. Calculate
a) The time taken to slow down to this velocity, (answer is 4s but how do I get it?)
b) The distance covered during the deceleration. (answer is 120m but how do I get it?)
Need help with these two. Sorry for the mess.
Thanks guys!
7a) If acceleration is the rate of change of velocity, how could you express a in terms of v, u and t? Rearrange for v
11a) Using the equation given in 7a, you need to pick out the numbers given in the question and plug them into the correct places to get out the answer you want. Can you do this?
b) You're going to need another equation involving distance. Do you know one or are you expected to derive it?
Got the first part of 7, thanks. Don't understand when they ask to "State the conditions that must be satisfied for the equation to be valid." though :/
For 11, what I've done so far is
v = u + at
10 = 50 + 9.81(t)
-40 = 9.81(t)
t = -4.0s
It's a negative number, I guess I'm supposed to flip it around?
As for part (b), I'm not sure myself. The equations I have around the paper are
v = u + at
v^2 = u^2 + 2as
s = ut + 1/2 at^2
I've tried using the s = ut + 1/2 at^2 one but I got an answer of 278.48m which is apparently wrong.
Thanks.
Good to hear!
The wonderful thing about maths is that there should be no need to "flip it around" the maths should do it all for you and you have made a mistake. Keep in mind that the plane decelerates at 10ms^-2. Can you think what might cause your stray negative sign to disappear now?
Given what I've said above, you've made the same mistake in the second part, so you should now be able to fix both.
I'll also just remind you that the question says the acceleration is 10ms^-2, but your second answer suggests that you are using 9.81, make sure you are being consistent (the answer quoted in your first post [120m] is the correct answer if you use a deceleration of 10ms^-2)
YES! Got it all! Homework completely, I can rest easy now. Thanks so much for all your help! :D
Excellent, no problem
