Questioning photoelectric effect theory
The discussion centers on the photoelectric effect, specifically how different light sources (HeNe Laser, Hg lamp, and LEDs) yield varying photocurrents despite the theory stating that only frequency matters. Participants agree that while frequency is crucial for the energy of emitted electrons, the intensity of light sources also influences the number of emitted electrons, thus affecting current. Additionally, the work function of different metals may contribute to discrepancies in observed currents. Further experimentation is necessary to clarify these factors.
  • Understanding of the photoelectric effect theory
  • Familiarity with light sources and their properties (frequency and intensity)
  • Knowledge of electron emission and work function of metals
  • Basic experimental design and data analysis skills
  • Investigate the relationship between light intensity and electron emission in the photoelectric effect
  • Explore the work functions of various metals and their impact on photocurrent
  • Conduct experiments comparing photocurrents from different light sources under controlled conditions
  • Learn about advanced photodetector technologies and their applications in measuring photocurrents
Students and researchers in physics, particularly those studying the photoelectric effect, experimental physicists, and educators seeking to enhance their understanding of light-matter interactions.
moonman
I'm working on a lab where I used LEDs of different wavelenths to record photocurrent they create when striking a metal. Using this data, i was able to find an equation relating the wavelength of the incident light to the current that is produced.
My problem is that when I repeated the experiment with different light sources (HeNe Laser, Hg lamp), the retarding potentials did not fit with the data from the LED's. The photoelectric effect says that the only thing that matters in the incident light is its frequency, because things like intensity are irrelevant. So I don't see why different light sources should create different currents. I don't know if what I said made any sense, but can anyone help me out here? Basically I'm asking if there are any other factors that would effect the current produced through the photoelectric effect other than frequency. I hope someone out there can help me out. thanks
Right and wrong.. the retarded potential is related to its frequency only, but the current is affected by its intensity,
different light sources has different frequence.. for example.. a red light has a lower frequence than a blue light.. surely you won't get a same result using different light source..
different light source not only have different frequency (color), their intensity (strength) varies, too..
The photoelectric effect theory is a fundamental concept in physics that explains how light can cause the emission of electrons from a metal surface. It states that the energy of the incident light (determined by its frequency) is responsible for the energy of the emitted electrons, while the intensity of the light does not affect this process.
Based on your experiment, it seems that you have found an equation relating the wavelength of the incident light to the current produced in the photoelectric effect. However, you have noticed that this equation does not hold true for all light sources, as the retarding potentials did not fit with the data from the LED's when using different light sources like a HeNe laser or Hg lamp.
This discrepancy raises an important question about the photoelectric effect theory. Are there other factors that could affect the current produced in the photoelectric effect, besides the frequency of the incident light?
One possible explanation for this inconsistency could be the different intensities of the light sources. While the photoelectric effect theory states that the intensity of the light does not affect the energy of the emitted electrons, it could still affect the number of electrons that are emitted. Therefore, it is possible that the different light sources used in your experiment had varying intensities, leading to different currents being produced.
Another factor that could potentially affect the current in the photoelectric effect is the surface properties of the metal being used. Different metals have different work functions, which is the minimum energy required to remove an electron from the surface of the metal. This could also contribute to the varying currents observed in your experiment.
In conclusion, while the photoelectric effect theory is a well-established concept, there may be other factors at play that could affect the current produced in the photoelectric effect. Further experimentation and analysis may be needed to fully understand the discrepancy you have observed in your experiment.
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 25 ·
