New Reply
Calculate the gas flow rate.
Share Thread Thread Tools
Apr18-12, 02:49 PM   #1
The pressure at the start of a 180Km stainless steel natural gas pipeline is 4MPa and at the end is 2MPa. If the diameter of the pipe is 0.4m, what will be the gas flow rate through the system? (ignore losses other than friction)
(For natural gas, ρ = 40 kg/m^3, μ = 11x10^-6 Pas).
2. Relevant equations
u = q/a
re = (u)(d)/v
hf = p/(density)(g)(Q)
3. The attempt at a solution.
Kinematic velocity; \nu=11x10-6/40 = 2.75*10-7
Reynolds number equation; Re = 1x10-6*0.4/2.75*10-7 = 16
Re number < 2100 => flow is laminar
From Moody's diagram, Friction Factor value = 0.002
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr20-12, 05:57 AM   #2
A problem such as this involves a trial and error solution. Guess a velocity at the given upstream pressure of 4MPa . From this, determine the downstream pressure. If the pressure is too high, guess another upstream velocity and recompute the downstream pressure. Repeat the process until computed downstream pressure is 2MPa. Based on the final velocity, compute the mass flow.
New Reply
Thread Tools
Similar Threads for: Calculate the gas flow rate.
Thread Forum Replies
To Calculate end Flow Rate of Water Mechanical Engineering 0
Calculate Velocities and Volume Flow Rate? Classical Physics 1
Calculate the flow rate of the etching solution Biology, Chemistry & Other Homework 3
How to calculate the flow rate of water supply using residual head? Engineering, Comp Sci, & Technology Homework 0
Calculate the individual flow rate - based on the pressure drop? Mechanical Engineering 0
