Finding the area between two curves
  • Thread starter Thread starter bansal
    Area Curves
The discussion revolves around finding the area enclosed by two curves, specifically the linear function y=x+1 and the quadratic function y=x^2-3x-4. The original poster has identified the points of intersection at x=-1 and x=5 and is seeking guidance on the next steps to calculate the area between these curves.
  • Participants suggest sketching the graphs and setting up an integral to find the area, discussing the height of the area strip as the distance between the functions. Some express confusion about the integration setup and the notation used for the area calculation.
There is ongoing exploration of different methods to approach the problem, including evaluating which function is on top and discussing the implications of the integral notation. Participants are questioning assumptions about the integration process and the necessity of graphing the functions.
Some participants note that the original poster may be new to integration concepts, raising concerns about the complexity of the problem and the appropriateness of the guidance provided. There is a mention of the potential for misunderstanding in the notation used for integrals.
bansal
find the area enclosed by the two curves
y=x+1 y=x^2-3x-4
i've already worked out the points of intersection. these are x=-1 and 5
what do i do now? and how? i'd appreciate if you could tell me because i have loads of these to do, so one good example would be great
Sketch the graphs and set up an integral for the area. The strip whose area is da would be a rectangle whose height is the distance between the functions. The width is dx. Integrate over the limits you already have determined.
i don't get what your saying :( could you show me?
This is very strange! Are you taking a Calculus course? Are you studying integration of functions?
If [itex]f(x)\ge g(x)[/itex] for all [itex]x_0\le x\le x_1[/itex] then the area between the curves is [itex]\int_{x_0}^{y_0} (f(x)- g(x))dx[/itex].
I can't imagine a person being asked to do a homework problem like this if they had never seen anything about integeration.
You need to sketch the graphs of those two curves to see the limits of integration.
The points of intersection are: (-1,0) and (5,6).
In this case, there are 2 ways of finding the area between those 2 curves. The simplest way is to describe the enclosed region like this:
For x fixed, y varies from y=... to y=...
x varies from x=... to x=...
Then, the answer consists of solving a double integral.
Despite what some people are saying, you don't need to sketch the graphs, though it is a nice sanity check of your answer.
You said you already have the points of intersection. The next step is to determine which function is on top. To do this, you can evaluate each function at a point in the middle of your 2 points of intersection and see which function is greater. (If you insist on doing it without graphing). This method is also good if you are dealing with functions whose shapes are not immediately obvious. Since in this problem the shapes are pretty particular, you can also do it by graphing the two functions and examining the region of interest.
You use integration to get the area under the top curve and subtract it by the area under the lower curve (using integration to find it too). This leaves the area in the middle of the two curves. HallsofIvy details this process. If you look at the graph above me, this can be visualized as "total area under the rhombus that is made from that linear line all the way down to the x-axis minus the total area under the U shaped curve all the way down to the x-axis (all between the 2 points of interest -- the two points of intersection)" That leaves the area of the figure that is sort of D shaped and rotated to the right a bit (the are between the curves).
I have a question about how to present your solution to questions like this, my question is trivial so I'll post here first and if no one answers I will post a new thread.
After finding the intercept points between the 2 functions, the equation you need to solve looks something like this...
area = ∫(x+1)-(x^2-3x-4) dx
I am wondering why there is only one "dx", to me this looks like it's saying we are only going to find the integral of (x^2-3x-4) and not (x+1).
Shouldn't it be presented like this?
area = ∫((x+1)-(x^2-3x-4)) dx
or this?
area = ∫(x+1) dx -(x^2-3x-4) dx
What am I missing here?
A double integral is NOT required in this problem, and is probably beyond the present capabilities of the OP.
When you post a response, try to ascertain the level at which the poster can comprehend your explanation.
or this?
Since you're not the OP of this thread, i believe that you should start a new topic, instead of hijacking this thread. But this will require confirmation from the moderators first.
I apologize for overlooking this aspect of helping with homework. I'm a novice volunteer and still learning.
As sharks said, when you post a question that is not related to the original post, you should start a new thread.
The integrand is everything between ∫ and dx, so there is a pair of implied parentheses there.
or this?
This first is fine, but most books don't bother with the extra parentheses, for the reason I gave.
The second is incorrect because there is no ∫ sign to go with the final dx.
One other thing. You do not "solve" an integral - you evaluate it. When you solve an equation (for some variable), you rewrite the equation in a form in which <some variable> is isolated on one side of the equation.
or this?
When you think about the properties of integrals, it is useful to consider a summation that approximates it since it is less mysterious. Consider this:
[tex]\sum(x+1)h-\sum(x^2-3x-4)h[/tex]
where we are summing small rectangles of width h and height equal to the functions evaluated at particular values of x (i.e. x+1 and x^2-3x-4). The summation would go from the lower limit to the upper limit with a step size of h (e.g. if h = .01 and the integral was from 0 to 1, you would sum up the values at x = 0, x = .01, etc.)
So we can work with these more intuitive summations to show how it equals the thing you are confused about it equaling. The sum of a plus the sum of b is the sum of (a+b). Are you comfortable with that? If so, we get
[tex]\sum[(x+1)h-(x^2-3x-4)h][/tex]
Then, h is just a number, so we can factor it out.
[tex]\sum[(x+1)-(x^2-3x-4)]h[/tex]
Then (a+b) - (c-d-e) = a+b-c+d+e...
[tex]\sum[x+1-x^2+3x+4]h[/tex]
Since an integral is basically this type of summation with h = dx as h goes toward 0, it is also true that
[tex]\int x+1 - x^2 +3x+4 dx=\int (x+1) dx - \int (x^2-3x-4) dx[/tex]
But since it makes no sense to have a term inside an integral that isn't multiplied by your dx, people just leave off that internal parentheses:
[tex]\int (x+1) dx - \int (x^2-3x-4) dx=\int x+1 dx - \int x^2-3x-4 dx[/tex]
Using this interpretation, I also see no problem with your writing of
as long as we put another bracket to indicate the infinite summation is over both portions
∫[(x+1) dx -(x^2-3x-4) dx]
Sorry, I read somewhere that I should read through the forum for similar questions before posting.
Thanks, I intend to leave no stone unturned in coming to understand every technical detail in A-level mathematics, I have covered "pure 1" so far and I will ask a bunch of well presented questions like this again tomorrow after going through "pure 2", all of which I will post in one new thread.
  • · Replies 59 ·
