Electric Field Strength Question
The discussion revolves around calculating the electric field strength created by a dipole consisting of two charges, +3C and -3C, separated by 1 meter. The original poster seeks assistance in determining the electric field strength at the midpoint between the charges.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the application of the superposition principle for calculating the electric field at a specific point. Questions arise regarding the values of charge and distance, as well as the method of vector addition for the electric fields from each charge.
There is an ongoing exploration of how to approach the problem, with some participants suggesting the use of superposition and vector addition without reaching a consensus on the specific calculations. Guidance has been offered regarding the conceptual framework needed to solve the problem.
Participants are navigating the implications of the dipole setup and the specifics of calculating electric fields from point charges, with some uncertainty regarding the values and setup. The original poster expresses confusion about the necessary parameters for the calculation.
DLxX
I need help with the following question.
A diopole is made up of two charges, Q1 and Q2, that are separated by a distance of 1 meter. Q1 has a charge of +3C and Q2 has a charge of -3C. What is the electric field strength of the field set up by these two charges at a point exactly halfway between them?
I know the formula for this type of question, and it seems fairly simple as far as just entering in the values, but I'm having a hard time figuring out what Q and the distance is going to be.
Hold on,what Q??The distance is half a meter...
You just have to add two vectors,that's it.
Daniel.
DLxX,
Have you heard of the superposition principle ? Do you know how to calculate the field at a certain distance from a point charge ?
Yeah its just superposition, just take the E field generated with respect to Q1 at the midpoint, as if Q2 did not exist, and add it to the E field generated with respect to Q2 at the midpoint, as if Q1 did not exist, and you should get your net E field.
Athalus
  • · Replies 17 ·
