Solving 2nd Order Diff EQ: G(x), Joe Needs Help
  • Context: Graduate
  • Thread starter Thread starter josephcollins
    Differential
The discussion revolves around solving a second order differential equation and finding a specific solution that remains finite as time approaches infinity. Participants explore the general solution, boundary conditions, and the implications of terms in the solution as time progresses.
  • Joe presents a general solution for the differential equation and seeks advice on determining a specific solution that remains finite as t approaches infinity.
  • Daniel points out a potential inconsistency in variable usage and suggests rejecting the positive exponential term for reasons related to boundedness.
  • Another participant clarifies the correct form of the general solution and emphasizes the importance of substituting initial conditions to find relationships between constants A and B.
  • Joe expresses uncertainty about the implications of the solution as t tends to infinity, noting that certain terms will diverge while others remain bounded.
  • Daniel reiterates that the problem requires a solution that is bounded at infinity, implying constraints on the value of B.
  • Joe acknowledges the issue with the exponential term diverging and seeks further clarification on how to adjust the coefficient B to satisfy the boundedness condition.
Participants generally agree on the need for the solution to remain finite as t approaches infinity, but there is no consensus on the specific values or adjustments needed for the constants A and B to achieve this.
There are unresolved assumptions regarding the behavior of the solution as t approaches infinity and the implications of the boundary conditions on the constants involved.
josephcollins
Can anyone offer some advice on this problem:
Obtain a general solution for the second order differential equation:
(d^2x/dx^2) - (dx/dt) - 2x = 10sint
I obtained the general solution and now need to determine the "solution which remains finite as t tends to infinity for which x=4 at t=0. Could anyone suggest how I may approach this
My general solution was:
G(x)= Ae^2x + Be^-x + cost - 3sint
Thanks for any help,
Joe
Sorry,they have to have th same variable.It's either "t" or "x",make up your mind.Else it would have to be a PDE.
I think u can reject the positive exponential for obvious reasons...
Daniel...
Well, one problem is you are confusing your dependent and independent variables!
x(t)= Ae2t+ Be-t+ cos(t)- 3 sin(t).
Now just substitute t= 0, x= 4 to get one equation in the two unknowns A and B.
Now what happens to e2t and e-t as t goes to infinity?
(sin(t) and cos(t) remain finite, of course). What do you need to do to make sure your solution doesn't go to infinity?
ok, I have my general solution:
x: Ae^2t + Be^-t +cost -3sint
putting in x=4 and t=0 I obtain
4=A+B+1
so 3=A+B and A=3-B
So My final solution is:
x=(3-B)e^2t +Be^-t +cost -3sint
Is this correct, could someone verify? How about the fact that t tends to infinity, does this alter my answer at all?
The problem specifically asks for the solution bounded at infinity.So that should give an idea about the value of B.
Daniel.
The problem I have now is seeing what the equation does as t tends to infinity, e^-t will tend to zero, but e^2t will just tend to infinity while cost and sint are periodic, could you help me with this please?
Joe
Joe
You've already found the problem and you already know what's going to happen as t goes to infinity. . e^(2t) is tending toward infinity as t goes to infinity. The problem specifies that the solution must remain finite as t goes to infinity, so you can't leave the e^(2t) in there, now can you? If you do, you're going to end up with a non-finite solution as t goes to infinity. What can you do with the coefficient B so that the problem term is no longer a factor (i.e. disappears)?
--J
  • · Replies 36 ·
9K
