Velocity of an electron in an electric field
The discussion revolves around the velocity of electrons accelerated by an electric field in a picture tube, specifically focusing on the calculations involved in determining their speed after traveling a certain distance from rest.
  • Participants explore the relationship between electric potential energy and kinetic energy, questioning the impact of distance on the calculations. There are attempts to derive the speed using different equations and values, with some participants revisiting their calculations based on feedback.
There is an ongoing exploration of the calculations involved, with participants providing alternative approaches and questioning assumptions made in previous attempts. Some guidance has been offered regarding the importance of considering distance in the calculations.
Participants note discrepancies in calculated speeds and express uncertainty about the accuracy of their results, indicating a need for further clarification on the assumptions and values used in their calculations.
zeralda21
In a picture tube (eg. a TV set) electrons are accelerated of an electric field. If the electric field strength is 100 kV / m and the electrons travel a distance 0.2 m from rest, what speed will they achieve?
E=U/d where E is electric field intensity, U is the voltage and d is the distance.
W=qU
F=qE
(mv^2)/2 = kinetic energy
I think that the potential electrical energy of the electron will be converted into kinetic energy. Hence:
W=qU=(mv^2)/2 or v=sqrt((2qU)/m). The charge and mass of an electron is known and so is the electrical field intensity. If I insert these values in the equation above I will get:
sqrt((2*1.602*10^(-19)*100*10^3)/9.11*10^(-31))=1.87..*10^8 m/s. The correct answer is 8*10^7 m/s.
hi zeralda21! :smile:
zeralda21 said:
In a picture tube (eg. a TV set) electrons are accelerated of an electric field. If the electric field strength is 100 kV / m and the electrons travel a distance 0.2 m from rest …
what about the distance? :wink:
You are right, I didn´t take that into consideration. Here is another try:
If W=qU and E=U/d, then of course W=qEd. If I set this equal to the kinetic energy and solve for v i end up with:
W=qEd=(mv^2)/2 ----> v=sqrt((2qEd)/m). When I insert values for q,E,d and m(which are all known) the answer is 6*10^7 m/s, much more accurate but I think the error is too large for an "approximation error". No? What do you guys say?
you got 18.7 (times 107) before, and you're multiplying by √(0.2) …
how do you get 6 ? :confused:
I am ashamed :redface:. The answer is 8.36*10^7 m/s. Thanks tiny-tim :smile:
you are humble yet contrite
o:) go in peace! o:)
  • · Replies 16 ·
